Installation & Licensing
Help! Window can't show the license box.
2 REPLIES 2
kittipongsh.l
236 Views, 2 Replies
I've installed the Revit Architecture 2012 conletely, but there is a problem which always happen. (I 'd installed it for three times) It shows the Lincnse Transfer Utility box and then I click 'sign in'. Then the another box popped up, but my computer cannot display it. So, I still cannot use the program. PLEASE help me. I think it occured because my PC, I want to know to to deal with it. PLEASE. T.T
**Removed screen shot with visible serial number
2 REPLIES 2
TravisNave
in reply to: kittipongsh.l
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Forums:
Hi kittipongsh.l:
Please do not post any screen shot that has your serial number information. I will send you an email through private message (envelope next to your account name at the top of this page).
Arlin Bibat
Administrator Productivity
