Installation & Licensing
New Member
m060810135
Message 1 of 3 (919 Views)
Help Me Inventor 2013 Error 1920
919 Views, 2 Replies
01-17-2013 10:41 AM
http://i779.photobucket.com/albums/yy71/beolovely/anh_zps0e3c5a28.jpg
This picture it error 1920 i try but not install program.
How do fix it. help me please
Curtis_Waguespack
Message 2 of 3 (915 Views)
Re: Help Me Inventor 2013 Error 1920
01-17-2013 11:32 AM in reply to: m060810135
Hi m060810135,
See this link for some related posts:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A2...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
TravisNave
Message 3 of 3 (897 Views)
01-17-2013 11:55 AM in reply to: m060810135
First and foremost, you absolutely have to install with local Administrator privileges.  Make sure UAC is disabled and your anti-virus is temporarily disabled.  You might even consider disabling your firewall.
Next, if you still have issues, you will want to make sure that the Network Service account has full access to the C:\Program Files\Common Files\ folder and its subfolders.  If that still doesn't work, try going into Services and change the service that is failing to start up with the local system account rather than the Network Service.
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
