• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Help Me Inventor 2013 Error 1920
    398 Views, 2 Replies
    01-17-2013 10:41 AM
    http://i779.photobucket.com/albums/yy71/beolovely/anh_zps0e3c5a28.jpg
    This picture it error 1920 i try but not install program.
    How do fix it. help me please
    Please use plain text.
    Curtis_Waguespack
    Re: Help Me Inventor 2013 Error 1920
    01-17-2013 11:32 AM in reply to: m060810135
    Hi m060810135,
    See this link for some related posts:
    http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A2...
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    TravisNave
    01-17-2013 11:55 AM in reply to: m060810135
    First and foremost, you absolutely have to install with local Administrator privileges.  Make sure UAC is disabled and your anti-virus is temporarily disabled.  You might even consider disabling your firewall.
    Next, if you still have issues, you will want to make sure that the Network Service account has full access to the C:\Program Files\Common Files\ folder and its subfolders.  If that still doesn't work, try going into Services and change the service that is failing to start up with the local system account rather than the Network Service.
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
