i got this problem..this 1st installation..PC spec..Windows XP Pro SP3..after installation successfull..i can't run ACAD 2002..see at the image below..hope got solution for this problem..thank you so much 🙂
1st
2nd
3rd
4th
It's most likely a .NET Framework issue. You might have to clean that all up. Also, use CTRL+PrintScreen from now on so you only screencap the selected window.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
AutoCAD 2002 is long time before product. The latest version is 2013.
Could you update the RTS327? In my memory, this hotfix could solve this license issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2524942&linkID=9240618
