Installation & Licensing
Hello guys..can u help me?? please..
2 REPLIES 2
afif90
206 Views, 2 Replies
Hye guys,i got problem with Mechanical 2012..i already Un-install the Mechanical 2012 at 'ADD OR REMOVE PROGRAM'
after Un-install i restart the pc, then the problem is..i want re-install back then i cant select part Mechanical 2012..see at image..
1st
2nd
3rd
Edited by
Discussion_Admin
Thank You&Best Regards,
Autodesk Reseller Malaysia
Mohd Afif
2 REPLIES 2
TravisNave
in reply to: afif90
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
afif90
in reply to: TravisNave
Thank you so much for the solution..i will try it.. 🙂
Mohd Afif
Administrator Productivity
