Installation & Licensing
Member
mcarpenter123
Message 1 of 11 (473 Views)
Having an install problem with civic 2010 on my 64bit
473 Views, 10 Replies
09-16-2011 11:30 PM
The option to choose 64bit isn't available from the drop down menu on the website. I tried to download the 32bit, it wasn't compatible. I checked the system requirements, it said win7 (32 or 64) bit. What can I do to get this version running on my machine?
Product Support
Message 2 of 11 (468 Views)
Re: Having an install problem with civic 2010 on my 64bit
09-17-2011 07:12 AM in reply to: mcarpenter123
If this from the EDU site, I would download the latest version.
David Lau
*Expert Elite*
DarrenP
Message 3 of 11 (463 Views)
09-17-2011 09:40 AM in reply to: david.lau
there wasn't a 64 bit version of civil 3d 2010 only 2011 & 2012
Member
mcarpenter123
Message 4 of 11 (445 Views)
09-20-2011 03:33 PM in reply to: DarrenP
OK but the thing is we have civic 2010 in class and I was told that 2011 and 2012 will not help because there is no backwards tec. Is autodesk just with-holding the download? I really need to get 2010 on this computer
Member
mcarpenter123
Message 5 of 11 (444 Views)
09-20-2011 03:35 PM in reply to: mcarpenter123
If you scroll threw the requirements it says windows 7 (32 or 64) so there must be something I'm doing wrong when downloading it. The error read something about choosing the right OS
Product Support
Message 6 of 11 (438 Views)
09-21-2011 06:03 AM in reply to: mcarpenter123
I talked to the Civil gurus and they mentioned that Civil 2010 didn't have a true  64 bit (x64) version.  You could still install the 32 bit (x86) version on an 64 bit (x64)  operating system.
Check out this reference post:
http://civil3dnovice.blogspot.com/2009/04/civil-3d-2010-install-clearing-up.html
David Lau
Member
mcarpenter123
Message 7 of 11 (421 Views)
09-30-2011 03:20 PM in reply to: david.lau
Thank you for asking about that. Sorry it took a minute to reply, I have been having problems logging into this site..     I downloaded      civil 3d 2010 again, it went al the way to the point were it opened the install screen, when I clicked OK to install I had these errors come up.
 1. Error applying transforms, verify that the specified transform paths are valid #267.
 2. Fail to initialize design review
 3. Recursion too deep; the stack overflowed.
After closing these error messages the install screen stalled and forced me to close it.
Message 8 of 11 (340 Views)
02-23-2012 07:42 PM in reply to: mcarpenter123
I experienced this exact issue earlier today. I have discovered the solution is to ensure that you'll need to uninstall any newer versions of Design Review before trying to install C3D2010.
It would seem that the fault occurs when it tries to install Design Review 2010 (which is a requirement for C3D2010) when you already have Design Review 2012 installed. Makes sense when you think of it. I just which the error message was a little more clear.
Member
Message 9 of 11 (251 Views)
Re: install problem with civil 3d 2010
12-04-2012 12:50 PM in reply to: mcarpenter123
I am attempting to install Civil 3D 2010 and am getting these error messages when I "Install Products" AutoCAD Civil 3D 2010 and Autodesk Vault 2010 (Client):
-error applying transfroms.  verify the the specified paths are valid.  #267
-Failed to initialize autodesk design review 2010.
When I hit the "back" button, this error then pops up:
-Recursion too deep; the stack overflowed.
The installation wizard then shuts down....
Any idea how to fix this?  I am currently running 2007 LDD.
Product Support
Message 10 of 11 (246 Views)
12-04-2012 12:51 PM in reply to: ronaldator
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
