I've had this working on this machine and server.
My license path is correct
I've set the timeout to as high as 2000000
My license on the server is up and running by server status
Ports are all open and returning desired return in IE
Not sure what to do next. I've read numerous threads and tried all the common stuff.
have you tried this: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-se...
i would use the Ip address of the license server and the hostname
DarrenP
Yes I've done that as well, I'm really at a loss as it must have been something that was installed after because it was working.
I believe it may be on the server end as my network guy says he can see it hitting the server. Any ideas where to start there? I do have another service running on the NLM. Could that be messing things up?
Some further testing shows I'm getting:
FLEXnet Licensing Checkout error: The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: 86063ACD_2014_0F
Vendor:Host: skywalker
License path: @skywalker;@10.35.10.11;C:\Program Files\Autodesk\AutoCAD 2014\LICPATH.LIC;
Flexnet Licensing error:-97,121
I've attached my log file
I don't see AutoCAD in your debug log. Are you sure it is licensed? Also, are you connecting to your NLM via IPv4?
