Hi have 2 PC's one is a w7 home 64 bits that i installed autocad 2012 i try whit the other PC that is an w7 ultimate 32 bit whit an 32 bit setup ACAD 2012 and i can't end installation becaseu its says the same error everytime i try , its FARO SDK and Direct x run time both give me errors and i can't move on instalation.
there is a log:
2012/1/19:00:12:11 Vitor Vitor-PC === Setup started on Vitor-PC by Vitor ===
2012/1/19:00:12:11 Vitor Vitor-PC Launch
2012/1/19:00:12:11 Vitor Vitor-PC Setup Windows update reboot is pending
2012/1/19:00:12:20 Vitor Vitor-PC Setup AutoCAD 2012 Will restart automatically.
2012/1/19:00:12:20 Vitor Vitor-PC === Setup ended ===
2012/1/19:00:14:32 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:00:14:32 Vitor VITOR-PC Launch
2012/1/19:00:15:52 Vitor VITOR-PC === Setup ended ===
2012/1/19:00:14:33 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:00:14:33 Vitor VITOR-PC Launch
2012/1/19:00:15:53 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:00:16:07 Vitor VITOR-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/1/19:00:19:49 Vitor VITOR-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/1/19:00:20:02 Vitor VITOR-PC === Setup ended ===
2012/1/19:00:22:08 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:00:22:08 Vitor VITOR-PC Launch
2012/1/19:00:22:34 Vitor VITOR-PC === Setup ended ===
2012/1/19:00:22:09 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:00:22:09 Vitor VITOR-PC Launch
2012/1/19:00:22:35 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:00:22:43 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:00:23:05 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:00:23:27 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:00:23:36 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:00:23:36 Vitor VITOR-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): G:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Vitor\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/1/19:00:23:55 Vitor VITOR-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/1/19:00:23:55 Vitor VITOR-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): G:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/1/19:00:24:13 Vitor VITOR-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/1/19:00:24:13 Vitor VITOR-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): G:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Vitor\AppData\Local\Temp\vcredist_x86_2010.log
2012/1/19:00:24:19 Vitor VITOR-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Succeeded
2012/1/19:00:24:19 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AI176B.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:00:24:36 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:00:24:36 Vitor VITOR-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:00:24:51 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:00:24:51 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:00:34:12 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:00:34:13 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AI176B.tmp\Media.mst"
2012/1/19:00:51:59 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:00:52:08 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
2012/1/19:00:52:08 Vitor VITOR-PC Rollback Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1619
2012/1/19:00:52:09 Vitor VITOR-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2012/1/19:00:52:09 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:00:52:12 Vitor VITOR-PC === Setup ended ===
2012/1/19:00:52:31 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:00:52:31 Vitor VITOR-PC Launch
2012/1/19:00:52:42 Vitor VITOR-PC === Setup ended ===
2012/1/19:00:52:42 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:00:52:57 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:00:52:59 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:00:53:09 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:00:53:16 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:00:53:16 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIE650.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:00:53:27 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:00:53:27 Vitor VITOR-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:00:53:37 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:00:53:37 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:00:54:12 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:00:54:13 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIE650.tmp\Media.mst"
2012/1/19:01:01:56 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:01:02:01 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
2012/1/19:01:02:01 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:01:02:04 Vitor VITOR-PC === Setup ended ===
2012/1/19:12:00:12 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:12:00:12 Vitor VITOR-PC Launch
2012/1/19:12:00:54 Vitor VITOR-PC === Setup ended ===
2012/1/19:12:00:13 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:12:00:13 Vitor VITOR-PC Launch
2012/1/19:12:00:54 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:12:01:07 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:12:01:11 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:12:01:23 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:12:01:36 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:12:01:36 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AI3F98.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:12:05:27 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:12:05:27 Vitor VITOR-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:12:05:41 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:12:05:41 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:12:07:07 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:12:07:07 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AI3F98.tmp\Media.mst"
2012/1/19:12:07:31 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:12:07:40 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
2012/1/19:12:07:41 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:12:31:19 Vitor VITOR-PC === Setup ended ===
2012/1/19:12:50:08 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:12:50:08 Vitor VITOR-PC Launch
2012/1/19:12:50:29 Vitor VITOR-PC === Setup ended ===
2012/1/19:12:50:09 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:12:50:09 Vitor VITOR-PC Launch
2012/1/19:12:50:29 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:12:56:20 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:12:56:24 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:12:56:39 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:12:56:45 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:12:56:46 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIF9F4.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:12:57:04 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:12:57:04 Vitor VITOR-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:12:57:15 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-9
2012/1/19:12:57:15 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:12:58:48 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:12:58:48 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIF9F4.tmp\Media.mst"
2012/1/19:12:59:06 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:12:59:15 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
2012/1/19:12:59:16 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:12:59:33 Vitor VITOR-PC === Setup ended ===
2012/1/19:12:59:53 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:12:59:53 Vitor VITOR-PC Launch
2012/1/19:12:59:53 Vitor VITOR-PC Setup Windows update reboot is pending
2012/1/19:13:00:19 Vitor VITOR-PC Setup AutoCAD 2012 Will restart automatically.
2012/1/19:13:00:19 Vitor VITOR-PC === Setup ended ===
2012/1/19:13:06:16 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:13:06:16 Vitor VITOR-PC Launch
2012/1/19:13:06:45 Vitor VITOR-PC === Setup ended ===
2012/1/19:13:06:45 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:13:07:15 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:13:07:19 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:13:07:29 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:13:07:42 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:13:07:42 Vitor VITOR-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:13:07:55 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:13:07:55 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:13:10:03 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:13:10:03 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIF5FE.tmp\Media.mst"
2012/1/19:13:11:37 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:13:11:37 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:13:15:08 Vitor VITOR-PC === Setup ended ===
2012/1/19:13:51:48 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:13:51:48 Vitor VITOR-PC Launch
2012/1/19:13:52:16 Vitor VITOR-PC === Setup ended ===
2012/1/19:13:52:16 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:13:53:16 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:13:53:26 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:13:53:51 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:13:54:43 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:13:54:43 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AIA69A.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:13:55:01 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:13:55:01 Vitor VITOR-PC Installing DirectX Runtime: C:\Users\Vitor\Desktop\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:13:55:18 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:13:55:18 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:13:56:20 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:13:56:20 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:13:58:28 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:13:58:36 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
2012/1/19:13:58:36 Vitor VITOR-PC PageOpen InstallCompleteDialog
2012/1/19:14:04:17 Vitor VITOR-PC === Setup ended ===
2012/1/19:14:04:23 Vitor VITOR-PC === Setup started on VITOR-PC by Vitor ===
2012/1/19:14:04:23 Vitor VITOR-PC Launch
2012/1/19:14:04:32 Vitor VITOR-PC === Setup ended ===
2012/1/19:14:04:32 Vitor VITOR-PC PageOpen LaunchDialog
2012/1/19:14:04:58 Vitor VITOR-PC PageOpen LicenseDialog
2012/1/19:14:05:10 Vitor VITOR-PC PageOpen ProductInfoDialog
2012/1/19:14:05:20 Vitor VITOR-PC PageOpen ProductSelectionDialog2
2012/1/19:14:05:24 Vitor VITOR-PC PageOpen FullProgressDialog
2012/1/19:14:05:25 Vitor VITOR-PC Installing Autodesk® Design Review: TRANSFORMS="C:\Users\Vitor\AppData\Local\Temp\_AI2B74.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:14:05:36 Vitor VITOR-PC Install Autodesk® Design Review Succeeded
2012/1/19:14:05:36 Vitor VITOR-PC Installing DirectX Runtime: C:\Users\Vitor\Desktop\3rdParty\DirectX\DXSETUP.exe /silent
2012/1/19:14:05:46 Vitor VITOR-PC Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/1/19:14:05:46 Vitor VITOR-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:14:06:47 Vitor VITOR-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/1/19:14:06:47 Vitor VITOR-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Vitor\Desktop\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/1/19:14:15:57 Vitor VITOR-PC Install Autodesk Material Library 2012 Failed Installation aborted, Result=1603
2012/1/19:14:16:02 Vitor VITOR-PC Rollback Autodesk® Design Review Succeeded
i just attched the problems of installation on the 2nd PC (32 bit)
Typically those failures are ignored. Copy the media to a folder on your local hard drive. Then login as another user, preferably the local administrator (or a user with local admin rights) and begin your installation again. Make sure that your anti-virus is temporarily disabled.
this is an admin acc and all the file are o my C.
I put off anti virus and the error persist.
the problem starts at FARO SDK.
It makes no sense on my Pc i already using ACAD 2012.
on my other PC i can't install it...
