Installation & Licensing
HELP! Revit 2012 installation failed with installation log file
0 REPLIES 0
Message 1 of 1
234 Views, 0 Replies
I am using student version of revit 2012. I try to install two times and the results are all three items(revit architecture, design review, material library) failed. Nothing happened during the whole process until the step of these three items.
The installation log file is as follow, but I only see the design review's:
2013/1/27:13:24:30 Owner OWNER-PC === Setup started on OWNER-PC by Owner ===
2013/1/27:13:24:30 Owner OWNER-PC Launch
2013/1/27:13:25:13 Owner OWNER-PC === Setup ended ===
2013/1/27:13:24:31 Owner OWNER-PC === Setup started on OWNER-PC by Owner ===
2013/1/27:13:24:31 Owner OWNER-PC Launch
2013/1/27:13:25:13 Owner OWNER-PC PageOpen LaunchDialog
2013/1/27:13:26:26 Owner OWNER-PC PageOpen LicenseDialog
2013/1/27:13:26:31 Owner OWNER-PC PageOpen ProductInfoDialog
2013/1/27:13:27:40 Owner OWNER-PC PageOpen ProductSelectionDialog2
2013/1/27:13:31:50 Owner OWNER-PC PageOpen FullProgressDialog
2013/1/27:13:31:50 Owner OWNER-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Owner\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/27:13:32:05 Owner OWNER-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/1/27:13:32:05 Owner OWNER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/27:13:32:39 Owner OWNER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/27:13:32:39 Owner OWNER-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Owner\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/27:13:32:42 Owner OWNER-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/1/27:13:32:42 Owner OWNER-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/27:13:32:42 Owner OWNER-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/27:13:32:43 Owner OWNER-PC PageOpen InstallCompleteDialog
2013/1/27:13:33:58 Owner OWNER-PC === Setup ended ===
2013/1/27:13:41:46 Owner OWNER-PC === Setup started on OWNER-PC by Owner ===
2013/1/27:13:41:46 Owner OWNER-PC Launch
2013/1/27:13:42:23 Owner OWNER-PC === Setup ended ===
2013/1/27:13:41:47 Owner OWNER-PC === Setup started on OWNER-PC by Owner ===
2013/1/27:13:41:47 Owner OWNER-PC Launch
2013/1/27:13:42:23 Owner OWNER-PC PageOpen LaunchDialog
2013/1/27:13:47:46 Owner OWNER-PC PageOpen LicenseDialog
2013/1/27:13:47:49 Owner OWNER-PC PageOpen ProductInfoDialog
2013/1/27:13:48:21 Owner OWNER-PC PageOpen ProductSelectionDialog2
2013/1/27:13:49:01 Owner OWNER-PC PageOpen FullProgressDialog
2013/1/27:13:49:01 Owner OWNER-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Owner\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/27:13:49:04 Owner OWNER-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
0 REPLIES 0
Administrator Productivity
