I have installed Autocad 2014 last few months successfully, but today while installing Revit 2015, it said "Installation completed. Some products failed to install." and it's related to error 1619 and 1603 problem. I've checked this forum but I can't really understand what to do exactly. Please help...
2014/7/18:19:44:27 Carol NAMNAMBEAN Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603 2014/7/18:19:44:31 Carol NAMNAMBEAN Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/7/18:19:45:29 Carol NAMNAMBEAN Rollback Autodesk Material Library 2015 Succeeded 2014/7/18:19:45:33 Carol NAMNAMBEAN Rollback Autodesk Workflows 2015 Succeeded 2014/7/18:19:45:48 Carol NAMNAMBEAN Rollback Autodesk® Revit® 2015 Language Pack Succeeded 2014/7/18:19:50:13 Carol NAMNAMBEAN Rollback Autodesk® Revit® 2015 Succeeded 2014/7/18:19:52:11 Carol NAMNAMBEAN Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2014/7/18:19:52:20 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2014/7/18:19:52:26 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2014/7/18:19:52:32 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2014/7/18:19:52:35 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2014/7/18:19:52:40 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2014/7/18:19:52:46 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2014/7/18:19:52:52 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2014/7/18:19:52:56 Carol NAMNAMBEAN Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Solved by TravisNave. Go to Solution.
Failure to download the image library.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
@Anonymous we would need to see your installation log to find the reason for the failure. Attach it.
Here you go, have tried two other times.... keeps deleting my post??
2014/11/6:14:32:00 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/6:14:32:00 andybouton ANDY2014 Path_Length: 166
2014/11/6:14:32:00 andybouton ANDY2014 Current Directory F:
2014/11/6:14:32:00 andybouton ANDY2014 Launch
2014/11/6:14:32:00 andybouton ANDY2014 CommandLine
2014/11/6:14:32:00 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp
2014/11/6:14:32:04 andybouton ANDY2014 === Setup ended ===
2014/11/6:14:32:04 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/6:14:32:06 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/6:14:32:09 andybouton ANDY2014 PageOpen ProductInfoDialog
2014/11/6:14:32:12 andybouton ANDY2014 PageOpen ProductSelectionDialog2
2014/11/6:14:33:32 andybouton ANDY2014 PageOpen FullProgressDialog
2014/11/6:14:33:32 andybouton ANDY2014 Installing Microsoft Visual C++ 2005 Redistributable (x86): "F:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/6:14:33:35 andybouton ANDY2014 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/11/6:14:33:35 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "F:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/11/6:14:33:37 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/11/6:14:33:37 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "F:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/11/6:14:33:41 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/11/6:14:33:41 andybouton ANDY2014 Installing Autodesk® Revit® 2015: TRANSFORMS="F:\x64\en-us\RVT2015\RVT2015.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:35:01 andybouton ANDY2014 Install Autodesk® Revit® 2015 Succeeded
2014/11/6:14:35:01 andybouton ANDY2014 Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\_laB22A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:35:04 andybouton ANDY2014 Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/6:14:35:05 andybouton ANDY2014 Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:05 andybouton ANDY2014 Install Autodesk Workflows 2015 Succeeded
2014/11/6:14:35:06 andybouton ANDY2014 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:11 andybouton ANDY2014 Install Autodesk® Material Library 2015 Succeeded
2014/11/6:14:35:11 andybouton ANDY2014 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:16 andybouton ANDY2014 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/11/6:14:35:16 andybouton ANDY2014 Installing Autodesk® Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:25 andybouton ANDY2014 Install Autodesk® Material Library 2015 - Low Image Library Succeeded
2014/11/6:14:35:26 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:26 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded
2014/11/6:14:35:26 andybouton ANDY2014 Installing DirectX Runtime: "F:\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/6:14:35:44 andybouton ANDY2014 Install DirectX Runtime Succeeded
2014/11/6:14:35:44 andybouton ANDY2014 Installing Autodesk® Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=F:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:35:46 andybouton ANDY2014 Install Autodesk® Content Service Succeeded
2014/11/6:14:35:47 andybouton ANDY2014 Installing Autodesk® Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:35:47 andybouton ANDY2014 Install Autodesk® Content Service Language Pack Succeeded
2014/11/6:14:35:48 andybouton ANDY2014 Installing Autodesk® AutoCAD® 2015: TRANSFORMS="F:\x64\en-us\acad\acad.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:37:26 andybouton ANDY2014 Install Autodesk® AutoCAD® 2015 Succeeded
2014/11/6:14:37:26 andybouton ANDY2014 Installing AutoCAD® 2015 Language Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\_laE8E5.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:37:40 andybouton ANDY2014 Install AutoCAD® 2015 Language Pack Succeeded
2014/11/6:14:37:40 andybouton ANDY2014 Installing AutoCAD® 2015 Product Specific Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\_laE8E5.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:37:48 andybouton ANDY2014 Install AutoCAD® 2015 Product Specific Pack Succeeded
2014/11/6:14:37:48 andybouton ANDY2014 Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:37:50 andybouton ANDY2014 Install SketchUp Import plug-in Succeeded
2014/11/6:14:37:50 andybouton ANDY2014 Installing Autodesk® ReCap™: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\x64\RC2015\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:38:12 andybouton ANDY2014 Install Autodesk® ReCap™ Succeeded
2014/11/6:14:38:12 andybouton ANDY2014 Installing Autodesk® Material Library 2015 - Medium Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:35 andybouton ANDY2014 Install Autodesk® Material Library 2015 - Medium Image Library Succeeded
2014/11/6:14:38:35 andybouton ANDY2014 Installing Exchange App Manager: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:35 andybouton ANDY2014 Install Exchange App Manager Succeeded
2014/11/6:14:38:36 andybouton ANDY2014 Installing Exchange Featured Apps plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:36 andybouton ANDY2014 Install Exchange Featured Apps plug-in Succeeded
2014/11/6:14:38:37 andybouton ANDY2014 Installing Autodesk® AutoCAD® Performance Reporting Tool: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:37 andybouton ANDY2014 Install Autodesk® AutoCAD® Performance Reporting Tool Succeeded Reboot is required
2014/11/6:14:38:37 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:38 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for AutoCAD® 2015 Succeeded
2014/11/6:14:38:38 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Update3 Redistributable (x86): "F:\3rdParty\x86\VCRedist\2012UPD3\vcredist_x86.exe" /q /norestart /l C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2012_upd3_60610.log
2014/11/6:14:38:42 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Update3 Redistributable (x86) Succeeded
2014/11/6:14:38:42 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Update3 Redistributable (x64): "F:\3rdParty\x64\VCRedist\2012UPD3\vcredist_x64.exe" /q /norestart /l C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x64_2012_upd3_60610.log
2014/11/6:14:38:46 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Update3 Redistributable (x64) Succeeded
2014/11/6:14:38:47 andybouton ANDY2014 Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:38:48 andybouton ANDY2014 Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Succeeded
2014/11/6:14:38:48 andybouton ANDY2014 Installing Autodesk® Navisworks® Simulate 2015: TRANSFORMS="F:\x64\en-us\NAVSIM\roamer.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\x64\NAVSIM\roamer-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:39:38 andybouton ANDY2014 Install Autodesk® Navisworks® Simulate 2015 Succeeded Reboot is required
2014/11/6:14:39:38 andybouton ANDY2014 Installing Autodesk® Navisworks® Simulate 2015 Language Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\_laEC24.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:39:55 andybouton ANDY2014 Install Autodesk® Navisworks® Simulate 2015 Language Pack Succeeded
2014/11/6:14:39:56 andybouton ANDY2014 Installing Autodesk® Revit® Interoperability for Navisworks® Simulate 2015: C_APP_NAME=NavisworksSimulate C_APP_VER=2015 C_RES=ALL RX_PD="Navisworks Simulate 2015\Loaders" ADDLOCAL=RevitEngine,RPC ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Update3 Redistributable (x86),Microsoft Visual C++ 2012 Update3 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,DirectX Runtime,;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:40:31 andybouton ANDY2014 Install Autodesk® Revit® Interoperability for Navisworks® Simulate 2015 Succeeded
2014/11/6:14:40:32 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2015 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:40:42 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2015 DWG File Reader Succeeded
2014/11/6:14:40:42 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2014 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:40:58 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2014 DWG File Reader Succeeded
2014/11/6:14:40:58 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2013 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:41:11 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2013 DWG File Reader Succeeded
2014/11/6:14:41:12 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2012 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:41:26 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2012 DWG File Reader Succeeded
2014/11/6:14:41:27 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2011 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:41:40 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2011 DWG File Reader Succeeded
2014/11/6:14:41:41 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2010 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:41:53 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2010 DWG File Reader Succeeded
2014/11/6:14:41:54 andybouton ANDY2014 Installing Navisworks® Simulate 2015 - 2009 DWG File Reader: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:42:06 andybouton ANDY2014 Install Navisworks® Simulate 2015 - 2009 DWG File Reader Succeeded
2014/11/6:14:42:06 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for Navisworks® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:42:07 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for Navisworks® 2015 Succeeded
2014/11/6:14:42:07 andybouton ANDY2014 Installing Autodesk® Navisworks® 64 bit Exporter Plug-ins: TRANSFORMS=F:\x64\en-us\NWEXPORT\Exporters.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7,.NET Framework Runtime 3.5 SP1,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Update3 Redistributable (x86),Microsoft Visual C++ 2012 Update3 Redistributable (x64),.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/6:14:42:18 andybouton ANDY2014 Install Autodesk® Navisworks® 64 bit Exporter Plug-ins Succeeded
2014/11/6:14:42:18 andybouton ANDY2014 Installing Autodesk® Navisworks® 64 bit Exporter Plug-ins English Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIED9A.tmp\Media.mst"
2014/11/6:14:42:20 andybouton ANDY2014 Install Autodesk® Navisworks® 64 bit Exporter Plug-ins English Language Pack Succeeded
2014/11/6:14:42:20 andybouton ANDY2014 Installing Autodesk® Application Manager: "F:\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/11/6:14:43:46 andybouton ANDY2014 Install Autodesk® Application Manager Succeeded
2014/11/6:14:43:47 andybouton ANDY2014 PageOpen InstallCompleteDialog
2014/11/6:14:44:11 andybouton ANDY2014 === Setup ended ===
2014/11/7:08:54:09 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/7:08:54:09 andybouton ANDY2014 Path_Length: 166
2014/11/7:08:54:09 andybouton ANDY2014 Current Directory F:
2014/11/7:08:54:09 andybouton ANDY2014 Launch
2014/11/7:08:54:09 andybouton ANDY2014 CommandLine
2014/11/7:08:54:09 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp
2014/11/7:08:54:29 andybouton ANDY2014 === Setup ended ===
2014/11/7:08:54:13 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/7:08:54:13 andybouton ANDY2014 Path_Length: 166
2014/11/7:08:54:13 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp
2014/11/7:08:54:13 andybouton ANDY2014 Launch
2014/11/7:08:54:28 andybouton ANDY2014 Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp\Setup\RevitSetup.dll
2014/11/7:08:54:28 andybouton ANDY2014 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/11/7:08:54:29 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:08:54:36 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:08:54:40 andybouton ANDY2014 PageOpen ProductSelectionDialog2
2014/11/7:08:55:08 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:08:55:10 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:08:55:19 andybouton ANDY2014 PageOpen BeginDeploymentDialog
2014/11/7:08:55:19 andybouton ANDY2014 CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 166
2014/11/7:08:55:31 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:08:55:38 andybouton ANDY2014 Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp\Setup\RevitSetup.dll
2014/11/7:08:55:38 andybouton ANDY2014 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/11/7:08:55:38 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:08:55:42 andybouton ANDY2014 PageOpen ProductInfoDialog
2014/11/7:08:56:35 andybouton ANDY2014 PageOpen ProductSelectionDialog2
2014/11/7:08:57:03 andybouton ANDY2014 PageOpen FullProgressDialog
2014/11/7:08:57:03 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "F:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/11/7:08:57:11 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/11/7:08:57:11 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "F:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/11/7:08:57:19 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/11/7:08:57:19 andybouton ANDY2014 Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:08:57:19 andybouton ANDY2014 Install Autodesk® Revit® Content Libraries 2015 Failed Failure is ignored, Result=1618
2014/11/7:08:57:19 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AIE1C7.tmp\Media.mst"
2014/11/7:08:57:19 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for Revit® 2015 Failed Installation aborted, Result=1618
2014/11/7:08:57:19 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1618
2014/11/7:08:57:19 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1618
2014/11/7:08:57:19 andybouton ANDY2014 PageOpen InstallCompleteDialog
2014/11/7:08:57:51 andybouton ANDY2014 === Setup ended ===
2014/11/7:11:29:19 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/7:11:29:19 andybouton ANDY2014 Path_Length: 166
2014/11/7:11:29:19 andybouton ANDY2014 Current Directory C:\Autodesk\BDSP2015
2014/11/7:11:29:19 andybouton ANDY2014 Launch
2014/11/7:11:29:19 andybouton ANDY2014 CommandLine
2014/11/7:11:29:19 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2C2F.tmp
2014/11/7:11:29:24 andybouton ANDY2014 === Setup ended ===
2014/11/7:11:29:23 andybouton ANDY2014 Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2C2F.tmp\Setup\RevitSetup.dll
2014/11/7:11:29:23 andybouton ANDY2014 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/11/7:11:29:24 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:11:29:27 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:11:29:34 andybouton ANDY2014 PageOpen ProductInfoDialog
2014/11/7:11:30:31 andybouton ANDY2014 PageOpen ProductSelectionDialog2
2014/11/7:11:31:20 andybouton ANDY2014 PageOpen FullProgressDialog
2014/11/7:11:31:20 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\BDSP2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/11/7:11:31:24 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/11/7:11:31:24 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\BDSP2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/11/7:11:31:28 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/11/7:11:31:28 andybouton ANDY2014 Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2C2F.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:05:40 andybouton ANDY2014 Install Autodesk® Revit® Content Libraries 2015 Succeeded
2014/11/7:12:05:40 andybouton ANDY2014 Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\BDSP2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2C2F.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:06:16 andybouton ANDY2014 Install Autodesk® Revit® 2015 Succeeded
2014/11/7:12:06:17 andybouton ANDY2014 Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2C2F.tmp\_laC9.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:06:24 andybouton ANDY2014 Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/7:12:06:24 andybouton ANDY2014 Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:06:26 andybouton ANDY2014 Install Autodesk Workflows 2015 Succeeded
2014/11/7:12:06:26 andybouton ANDY2014 Installing Autodesk® Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:06:34 andybouton ANDY2014 Install Autodesk® Material Library 2015 - Low Image Library Succeeded
2014/11/7:12:06:34 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\BDSP2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:12:07:30 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for Revit® 2015 Failed Installation aborted, Result=1603
2014/11/7:12:07:37 andybouton ANDY2014 Rollback Autodesk® Material Library 2015 - Low Image Library Succeeded
2014/11/7:12:07:37 andybouton ANDY2014 Rollback Autodesk Workflows 2015 Succeeded
2014/11/7:12:07:38 andybouton ANDY2014 Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/7:12:07:47 andybouton ANDY2014 Rollback Autodesk® Revit® 2015 Succeeded
2014/11/7:12:08:01 andybouton ANDY2014 Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2014/11/7:12:08:02 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2014/11/7:12:08:02 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2014/11/7:12:08:02 andybouton ANDY2014 PageOpen InstallCompleteDialog
2014/11/7:12:08:23 andybouton ANDY2014 === Setup ended ===
2014/11/7:12:08:28 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/7:12:08:28 andybouton ANDY2014 Path_Length: 166
2014/11/7:12:08:28 andybouton ANDY2014 Current Directory C:\Autodesk\BDSP2015
2014/11/7:12:08:28 andybouton ANDY2014 Launch
2014/11/7:12:08:28 andybouton ANDY2014 CommandLine
2014/11/7:12:08:28 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2BF.tmp
2014/11/7:12:08:32 andybouton ANDY2014 === Setup ended ===
2014/11/7:12:08:31 andybouton ANDY2014 Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\ANDYBO~1\AppData\Local\Temp\_AI2BF.tmp\Setup\RevitSetup.dll
2014/11/7:12:08:31 andybouton ANDY2014 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/11/7:12:08:32 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:12:08:35 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:12:08:38 andybouton ANDY2014 PageOpen ProductInfoDialog
2014/11/7:12:10:11 andybouton ANDY2014 === Setup ended ===
2014/11/7:13:00:56 andybouton ANDY2014 === Setup started on ANDY2014 by andybouton ===
2014/11/7:13:00:56 andybouton ANDY2014 Path_Length: 166
2014/11/7:13:00:56 andybouton ANDY2014 Current Directory C:\Autodesk\Autodesk_Building_Design_Suite_Premium_2015_English_Win_32_64bit_wi_en-us
2014/11/7:13:00:56 andybouton ANDY2014 Launch
2014/11/7:13:00:56 andybouton ANDY2014 CommandLine /url "http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/Autodesk_Building_Design_Suite_Premium_201... /akamai /auth authparam /sid SESSION_ID
2014/11/7:13:00:56 andybouton ANDY2014 Current Directory C:\Users\ANDYBO~1\AppData\Local\Temp\_AICAF.tmp
2014/11/7:13:06:51 andybouton ANDY2014 === Setup ended ===
2014/11/7:13:01:43 andybouton ANDY2014 Download Play SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/SET...
2014/11/7:13:06:51 andybouton ANDY2014 Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/SET...
2014/11/7:13:06:51 andybouton ANDY2014 PageOpen LaunchDialog
2014/11/7:13:07:01 andybouton ANDY2014 Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\ANDYBO~1\AppData\Local\Temp\_AICAF.tmp\Setup\RevitSetup.dll
2014/11/7:13:07:01 andybouton ANDY2014 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/11/7:13:07:02 andybouton ANDY2014 PageOpen LicenseDialog
2014/11/7:13:07:07 andybouton ANDY2014 PageOpen ProductInfoDialog
2014/11/7:13:08:06 andybouton ANDY2014 PageOpen ProductSelectionDialog2
2014/11/7:13:08:33 andybouton ANDY2014 PageOpen FullProgressDialog
2014/11/7:13:08:36 andybouton ANDY2014 Download Play VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/VCR...
2014/11/7:13:08:47 andybouton ANDY2014 Download Complete VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/VCR...
2014/11/7:13:08:47 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/11/7:13:08:50 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/11/7:13:08:51 andybouton ANDY2014 Download Play VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/VCR...
2014/11/7:13:09:00 andybouton ANDY2014 Download Complete VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/VCR...
2014/11/7:13:09:00 andybouton ANDY2014 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ANDYBO~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/11/7:13:09:04 andybouton ANDY2014 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/11/7:13:09:04 andybouton ANDY2014 Download Play RCL2015 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RCL...
2014/11/7:13:09:21 andybouton ANDY2014 Download Complete RCL2015 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RCL...
2014/11/7:13:09:21 andybouton ANDY2014 Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AICAF.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:01:55 andybouton ANDY2014 Install Autodesk® Revit® Content Libraries 2015 Succeeded
2014/11/7:14:01:56 andybouton ANDY2014 Download Play RVT2015 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RVT...
2014/11/7:14:16:54 andybouton ANDY2014 Download Complete RVT2015 http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RVT...
2014/11/7:14:16:54 andybouton ANDY2014 Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\ANDYBO~1\AppData\Local\Temp\_AICAF.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:17:18 andybouton ANDY2014 Install Autodesk® Revit® 2015 Succeeded
2014/11/7:14:17:19 andybouton ANDY2014 Download Play RVT2015_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RVT...
2014/11/7:14:17:38 andybouton ANDY2014 Download Complete RVT2015_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/RVT...
2014/11/7:14:17:38 andybouton ANDY2014 Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\ANDYBO~1\AppData\Local\Temp\_AICAF.tmp\_la46C6.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:17:41 andybouton ANDY2014 Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/7:14:17:41 andybouton ANDY2014 Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:17:42 andybouton ANDY2014 Install Autodesk Workflows 2015 Succeeded
2014/11/7:14:17:43 andybouton ANDY2014 Download Play CMILL http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/CMI...
2014/11/7:14:22:55 andybouton ANDY2014 Download Complete CMILL http://efulfillment.autodesk.com/SWDLDNET4/2015/BDSPRM/WI/{4CCD8710-521B-4709-B207-CE5C11BC6E8F}/CMI...
2014/11/7:14:22:55 andybouton ANDY2014 Installing Autodesk® Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:23:02 andybouton ANDY2014 Install Autodesk® Material Library 2015 - Low Image Library Succeeded
2014/11/7:14:23:02 andybouton ANDY2014 Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Premium 2015" SETUP_PACKAGECODE={D39D2992-7582-4630-AD32-1C493E239EE2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Premium 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/7:14:31:11 andybouton ANDY2014 Install Autodesk® BIM 360™ Add-in for Revit® 2015 Failed Installation aborted, Result=1603
2014/11/7:14:31:20 andybouton ANDY2014 Rollback Autodesk® Material Library 2015 - Low Image Library Succeeded
2014/11/7:14:31:20 andybouton ANDY2014 Rollback Autodesk Workflows 2015 Succeeded
2014/11/7:14:31:21 andybouton ANDY2014 Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/7:14:31:30 andybouton ANDY2014 Rollback Autodesk® Revit® 2015 Succeeded
2014/11/7:14:31:46 andybouton ANDY2014 Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2014/11/7:14:31:46 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2014/11/7:14:31:46 andybouton ANDY2014 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
When I post the log file my whole post goes away.
Any idea what I am doing wrong?
It's a known spam measure on the forum that is currently breaking the posts. Autodesk is dealing with it.
I got your PM. Here is the error:
I have instructed other users to do a custom install and uncheck the BIM 360 option during install. This will allow the rest of the program to install successfully. Then if you decide you want BIM 360, for some reason, you can go back and add it in afterwards.
Hopefully that works for you.
Thanks, will try this.
As I type, Hagerman called back and has deleted the 360 files and trying another load without it checked. Just Revit and Content. Maybe this time will be a charm!!
Perfect. Hope it works out for you.
I have recently purchased Autodesk Building Design Suite Premium 2015. There is a red x next to all of the products. Can you please help.
@Anonymous post the installation log file from your failure screen and it will help explain why.
Thanks.
Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
Yours is pretty vague.
I would say to start, do the following (making sure no other Autodesk 2015 verticals are already installed):
1. Install from the C:\ drive instead of the E:\ drive. If this is media, copy it to your local C:\ first then install.
2. Make sure you do a custom install and do not install any updates or service packs with the install.
3. Install with local admin rights, UAC off, and anti-virus disabled.
Good Luck!
I am getting a similar error. Looks like it is at Navisworks 2009....Please advise. Thank you.
Hi Travis,
We're getting the same thing here. Interesting, we've already successfully installed a quantity of Revit 2015 seats without issues. However, using the BDS setup fails unless I remove the BIM 360 applet everywhere it displays (in at least three apps).
I haven't tested from different install locations, but I think this is about the installer thinking that BIM 360 is installed, even when Windows says that it's not.
Makes sense. I marked your post #8, which most clearly describes the route to successful installs.
I had the same problem. I almost sent a post regarding my situation but I first took I look at similar problems and this helped me to solved my issue. Thanks @TravisNave It worked perfectly for me!
