Installation & Licensing
Message 1 of 8
kragland
802 Views, 7 Replies
HELP CRC Failure
What is this?  I have received this in 6 download attempts.  C3D will download and get about 98% or so installed and I get this message.   The latest (civil 3d 2012):
CRC failed in x64\en-US\C3D\Civil\Program Files\Root\Help\Civil Tutorials\Point Cloud.las  Unexpected end of archive
This is just one of 6 failed notices, it also says corrupted files in this one, language packs, direct x 9 (i'm running 11 so that shouldn't be a problem) so on and so forth.
Is there a problem with the server?  Last spring it took about 4-6 hours to download, this time it takes anywhere from 14-16 hours.
I have done everything the tutorial said to do, and I still get these problems.
system:
Dell Inspiron 560
Pentium Dual-Core CPU  E5700 @ 3.00 GHz
4 meg RAM
64-bit Windows 7
Nvidia FX 580 (I think)
How can I download and install this program without getting corrupted files?
Tags (1)
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: kragland
Don't use the download manager when downloading the files.  Use the alternate broswer method and save the files manually.  This typically resolves any CRC issues.
Autodesk Forums:
Message 3 of 8
kragland
in reply to: TravisNave
Thanks I'll give it a try
Message 4 of 8
kragland
No go,  I got a CRC failure in x86\en-US\Components\SSA2012\SSA 2012\Database\Storm Sanitary.MDB      after saving and manualy installing.
Message 5 of 8
kragland
http://forums.autodesk.com/t5/Installation-Licensing/HELP-CRC-Failure/td-p/3136462
This is getting down right ridiculous.    I NEED this for a class that has already started!
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Message 6 of 8
Aurala788
Have you figured out the problem to this?
My 3ds max is reporting the same problem!!
HELP ANYONE!
Message 7 of 8
TravisNave
Might try it from another computer then.  Make sure antivirus is off.
Autodesk Forums:
Message 8 of 8
kragland
Nothing has worked so far,  antivirus has been off during download
Administrator Productivity
