Installation & Licensing
HELP!!!!! Autodesk Component has stopped working and needs to close
4 REPLIES 4
RuyShellsoft
3621 Views, 4 Replies
Hi to All,
is there anyone out there that can help me solve this error?
i have a AutoCAD Architecture 2011 License. I've already activated it last year, to my surprize when i launch the ACA, the Activation dialog box appears again, asking me for a new activation code, so, i called our reseller and get a new activation code.
the problem is when i'm finished typing the activation code and click the NEXT button in the Activation Dialog box. this error appears:
"Autodesk Component has stopped working and needs to close."
please see the attached file thats the exact error that appears during my activation..
can anyone help me on this?
thanks in advance!
4 REPLIES 4
david.lau
in reply to: RuyShellsoft
If you have a Wacom tablet software installed, can you uninstall it and continue registered AutoCAD Architecture.
David Lau
RuyShellsoft
hi David,
thanks for the immediate reply..
i just want to ask what is  Wacom tablet software?
whats it's function?
i have no idea about it.
but i'll check in my workstation and will post an update..
thanks!
were you ever able to come to a solution for this issue? i started having the same problem today for no reason at all. Thanks!
Hello !
 Did  you have any solution  for this issue ? I have the same problem when trying to active autocad 2011 , same error 'autodesk component stopped working"  and it seems that nobody from autodesk support nor community could find the solution...
2 weeks I can't work...
Administrator Productivity
