I got i touch with Autodesk through Tweeter, but they delegated the problem to a thread which unfortunately does not help me.
Could you please help me with my Fusion 360 installation?:
"(Errno 13) Permission denied:
'/User/alejandrobona/Applications/Autodesk
Fusion 360.app'. Please attach the file
"/User/alejandrobona/Library/Logs/autodesk.webdeploy.streamer.log"
to any problem reports before closing
this dialog."
I have an 2.53 GHz Intel Core 2 Duo Macbook Pro 13 running OSX 10.7.5
It installs runs, but crashes unexpectedly. When I wish to run it again the application icon does not appear in my Applications folder and I have to run the installer again, which opens the program but also gives me the same error message.
Thank you for your time and consideration.
Hello and Welcome to the Community!
You are reporting problems with running Fusion 360 after installing it on your Mac book Pro 13 running on OSX 10.7.5. You are receiving an error message (Errno 13) Permission denied. This error could be caused by your permission settings or corruption with the installation.
- Are you having problems with any other recently installed applications?
- Do you get the same error message when logging in as root (sudo)?
Enabling and using the "root" user in Mac OS X
http://support.apple.com/kb/ht1528
- Locate the parent folder for where Fusion 360 is installed. Make sure the extended permissions for everyone has ‘read & write’ access. You can access the extended permissions by selecting the folder/file, click ‘file’ up at the top and locate ‘get file’. For details please refer to the link:
- To rule out possible corruption, please try uninstalling and reinstalling Fusion 360.
How to do a clean uninstall of Autodesk Fusion 360
http://knowledge.autodesk.com/article/How-to-do-a-clean-uninstall-of-Autodesk-Fusion-360
Thanks for the reply Brad!
I have Read & Wite permissions in my user session.
I did a clean uninstall as user and found that in $TMPDIR/Autodesk there was only the BrowserCache folder, all the others were missing.
When I reinstall I get the same Errno 13 message.
When I install it as "root" there is no Errno 13 message, but when I try to run it I get the following message in the Fusion 360 browser:
xoauth_problem=parameter_rejected&xoauth_parameters_absent=oauth_redirect_url&oauth_error_message=Invalid+value+for+parameter%3aoauth_redirect_url
Also, when I then log out of root and return to my user/adminstrator session, there is no Fusion 360 on my dock and the folders in Application Support are different to those in "root".
Hello, Could run the Disk Utility tool? The tool helps to repair problems with the disk and permissions. See links for details.
About Disk Utility's Repair Disk Permissions feature http://support.apple.com/kb/ht1452
How to speed up your Mac by verifying and repairing disk permissions http://www.imore.com/how-speed-your-mac-verifying-and-repairing-disk-permissions
Troubleshooting permissions issues in Mac OS X http://support.apple.com/kb/ht2963
Please let us know if the tool helps to resolve your problem.
Hi Brad,
I verified and repaired, ran the installer again to get the same (Errno 13) message.
Also, when I start the Fusion 360 I installed through "root" (found on: /$HOME/Library/Application Support/Autodesk/webdeploy/production/242567bf6bf58e972265608d3d37f3926e260030) I am getting the same message where the Dashboard should be:
"xoauth_problem=parameter_rejected&xoauth_parameters_absent=oauth_redirect_url&oauth_error_message=Invalid+value+for+parameter%3aoauth_redirect_url"
Could you attach the "autodesk.webdeploy.streamer.log" file refenced in the original post?
Also, is the Date and Time set correctly to match the local time zone?
I have the same problem. Find my log attached.
Can you provide help?
Best,
Wolfgang
Hi Wolfgang!
Welcome to the Autodesk community! In the attached error log, I note the below syntax:
"adsk.dls.streamer.exceptions.LockedRegistry: An installation is already in progress"
This error generally occurs when the installer is launched multiple times. It looks like you are on Can you open the Activity Monitor (Mac OS) or the Task Scheduler (Windows) and search for any process named Streamer or Fusion 360 Client Downloader.
Force Quit or End any of these processes and then restart the installer file. After doing this, I believe the installation will be successful.
I hope this suggestions helps. Please let me know if there are any question or complication.
Best,
Hi Nathan,
unfortunately this does not work.
I do not have an application called named Streamer or Fusion 360 Client Downloader running.
When installing Fusion I get the Error message and when I do nothing Fusion 365 is opened, but it is not installed...
Then both - the installer + the software - is running at the same time.
When I close Fusion 365 it is gone and not installed.
Any idea what to do?
Best,
Wolfgang
Is this the first time installing the application? If so, are you installing from the Mac Apple Store or the Autodesk website?
If you're installing from the Mac Apple Store, you should find a "Fusion 360.app" in the Application Folder. Do you find it there?
If you're isntalling from Autodesk website, you may browse to the below directory and search for a file named "Autodesk Fusion 360.app"
Macintosh HD/Users/<PROFILENAME>/Library/Application Support/Autodesk/webdeploy/production/<ID>/
If this is not your first time installing, it may be a good idea to start fresh. This may be the fastest solution whether or not you have installed before.
Please let me know if this suggestion helps or if there are any questions.
i have same problem too..
my laptop is ASUS A45V 2GB RAM and the OS is windows 10 . This is my first time install Fusion 360 and i dont have installation problem with previous autodesk product.
That's is my problem,and i already found the "autodesk.webdeploy.streamer.log" but i dont know how to attach that file to any problem report... what's is the meaning ?
i'm very appreciate for your help,and i wait for that. Thanks 🙂
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
Since you’re new to the community I just wanted to inform you this is a worldwide (public) user forum where users are assisting others. For any future postings you may do, please do not include any personal information (such as your serial #) in anything that you share (including screen shots & attachments) with us.
You do not have the same exact problem as the original poster or the others that are posting here. In the future (unless its the same exact problem - Errno 13) create your own posting so it can be resolved correctly.
For your issue please see this.
Mark Lancaster
& Autodesk Services MarketPlace Provider
The error messageis referencing the installation log file. On Windows 10, the below link can help you to locate the installation log file.
If you don't mind, could you reply with the installation log file attached?
On a side note, there is a collection of Installation and Update related solution articles in the below link that may help as well.
https://knowledge.autodesk.com/community/collection/16661
I hope that helps!
