• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Re: Forbidden installation with Windows 7 Enterprise, Applocker and Autodesk Pro
    02-22-2012 09:21 AM in reply to: neilgwood
    Hello Neil,
    The solution that you provided did not work. Thanks for sending the code.
    Please keep all interested parties here updated on a solution
    Thanks for your comments,
    Clint Hill
    Please use plain text.
    02-22-2012 09:29 AM in reply to: jeremy.burke
    As you, I would like a resolution as I have no issues installing other non-Autodesk software.
    Clint Hill
    Product Support
    02-22-2012 09:55 AM in reply to: chillme1
    Hi All;
       I have ran several tests over here on several Autodesk applications and haven't had any issues so at this point I haven't been able to reproduce this issue. It's possible that the configuration / setup is a bit different. If you have any specific configuration you would be happy to test this out for you but at this point we have yet to reproduce so I can't offer a fix.
      If you have subscription and would like to send us more details I would suggest logging a service request and the tech will gather information for the QA teams to see if they can offer any further information.
    Dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    New Member
    06-19-2012 02:33 AM in reply to: neilgwood
    Thanks for the workaround. Made the batch file, ran it, install the program. Help me out a lot since this is for my college class.
    New Member
    jeremy.burke
    06-19-2012 07:09 AM in reply to: neilgwood
    Hi Jeremy,
      Ok I've logged the defect and we'll just need the QA team to verify the defect which shouldn't take to long. I'll send any updates that they have for you.
    Best regards,
    Dwayne Poot
    Autodesk Support Team
    Hi Jeremy,
      Unfortunately there hasn't been any updates from the developers. I have been working with the Maya developers since I was able to reproduce it but they haven't been able to find a fix for this.
      I can't promise when the developers will have a update / work around for this. I think the only option at this point is to turn off the Applocker rules during the Autodesk installations.
    Best regards,
    Dwayne Poot
    Product Support
    06-20-2012 08:03 AM in reply to: jeremy.burke
    HI All;
        I ran a few tests with the 2013 installers and they seem to install fine with AppLocker enabled with default rules turned on. Unfortunately some of the 2012 installers are still effected.
    dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Member
    06-22-2012 02:00 AM in reply to: Dwayne.Poot
    Hi
    I will just tell that even i am not able to install Autodesk 2013 product, neither made deployments with Applocker just installed and not activated in our european part of the domain (where we are located).  (only Win 7 x64 available for test)
    Today i will try with an virtual computer not added to the domain, not the prefered way...
    Next month i want to roll out 400 Acad`s. Hotfix for this would be great :-)
    We do not see this probelm in other applications, and there is many of them...
    steinars
