I just downloaded the upgrade to Alias Surface 2013 and replaced my license file on the server. I receive a license error on the workstation of -15.570.10035 and it will not get a license. I tried the license parser and it shows my file is good for 2013 but it will not open. When I look at the server it shows "Users of CatV5DCf: Cannot get users of CatV5DCf: No such feature exists.
Feature: 85300SURFST_F
License Path:27000@myserver
FLEXnet licensing error: -5,222
If anyone could assist it would be appreciated.
Solved by TravisNave. Go to Solution.
Did you reread the license file? -5 means the product doesn't exist. Does your status enquiry show the license available?
Then it is not going to work. Stop the service then repath to the correct *new* license file on the Config Services tab. Save, the start the license service again. Do another status enquiry. Post the the results.
did you generate a license file for 2013?
DarrenP
that doesn't make any sense
something else is going on then
DarrenP
Agreed. You are obviously not pointing to the correct file in the saved service. Remove the service and then redo it all. Save. Start.
Post your status enquiry results here with CTRL+C CTRL+P.
I have combined my entire Alias license file with my AutoCad license file and configured only one service. It appears to be working now.
That's how it is done, son! Don't forget to mark the thread as solved. Thanks!
