Installation & Licensing
BobGriffin4044
355 Views, 4 Replies
Flexlm Crashes
Hello and Thanks in Advance for any help.
I have Autodesk 2008 installed and LMTOOLS 11.4 installed on my license server which is running Windows Server 2003. For the most part the license server works fine. However if I logoff of the server Flexlm stops running and I need to restart the license server process. Has anyone seen the before?
4 REPLIES 4
in reply to: BobGriffin4044
In LMTools, set it to run as a Service.
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:5862465@discussion.autodesk.com...
before?
TravisNave
Yes, and make sure that 'Start Server at Power Up' and 'Use Services' is checked in the Config Services tab of LMTOOLS.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Oh, yeah, that too!
Thanks Travis.
Sam Hochberg
wrote in message news:5862719@discussion.autodesk.com...
Thanks a ton!
Life is good again.
Administrator Productivity
