I've got serious problem with licensing smoke 2013 Ext 1 on MAC
I've been trying start lmgrd with option -c and license in terminal and I've got this:
0:35:16 (lmgrd) Please Note:
10:35:16 (lmgrd)
10:35:16 (lmgrd) This log is intended for debug purposes only.
10:35:16 (lmgrd) In order to capture accurate license
10:35:16 (lmgrd) usage data into an organized repository,
10:35:16 (lmgrd) please enable report logging. Use Flexera Software LLC's
10:35:16 (lmgrd) software license administration solution,
10:35:16 (lmgrd) FlexNet Manager, to readily gain visibility
10:35:16 (lmgrd) into license usage data and to create
10:35:16 (lmgrd) insightful reports on critical information like
10:35:16 (lmgrd) license availability and usage. FlexNet Manager
10:35:16 (lmgrd) can be fully automated to run these reports on
10:35:16 (lmgrd) schedule and can be used to track license
10:35:16 (lmgrd) servers and usage across a heterogeneous
10:35:16 (lmgrd) network of servers including Windows NT, Linux
10:35:16 (lmgrd) and UNIX. Contact Flexera Software LLC at
10:35:16 (lmgrd) www.flexerasoftware.com for more details on how to
10:35:16 (lmgrd) obtain an evaluation copy of FlexNet Manager
10:35:16 (lmgrd) for your enterprise.
10:35:16 (lmgrd)
10:35:16 (lmgrd) -----------------------------------------------
10:35:16 (lmgrd)
10:35:16 (lmgrd)
10:35:16 (lmgrd) FlexNet Licensing (v11.11.1.1 build 119913 x64_mac10) started on 127.0.0.1 (Mac) (11/27/2013)
10:35:16 (lmgrd) Copyright (c) 1988-2013 Flexera Software LLC. All Rights Reserved.
10:35:16 (lmgrd) World Wide Web: http://www.flexerasoftware.com
10:35:16 (lmgrd) License file(s): adsk_server.lic
10:35:16 (lmgrd) lmgrd tcp-port 27009
10:35:16 (lmgrd) Starting vendor daemons ...
10:35:16 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:16 (lmgrd) Started adskflex (internet tcp_port 2081 pid 554)
10:35:16 (adskflex) Unable to initialize access to trusted storage: 1
10:35:16 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:16 (adskflex) Server started on 127.0.0.1 for:
10:35:16 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:16 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:16 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:16 (adskflex) 85737SMKMACWG_2012_0F)
10:35:16 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:16 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:16 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:16 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:16 (adskflex) EXTERNAL FILTERS are OFF
10:35:16 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:16 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:16 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:16 (lmgrd) Since this is an unknown status, license server
10:35:16 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:16 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 555)
10:35:17 (adskflex) Server started on 127.0.0.1 for:
10:35:17 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:17 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:17 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:17 (adskflex) 85737SMKMACWG_2012_0F)
10:35:17 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:17 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:17 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:17 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:17 (adskflex) EXTERNAL FILTERS are OFF
10:35:17 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:17 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:17 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:17 (lmgrd) Since this is an unknown status, license server
10:35:17 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:17 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:17 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 556)
10:35:17 (adskflex) Unable to initialize access to trusted storage: 1
10:35:17 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:17 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 557)
10:35:18 (adskflex) Server started on 127.0.0.1 for:
10:35:18 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:18 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:18 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:18 (adskflex) 85737SMKMACWG_2012_0F)
10:35:18 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:18 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:18 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:18 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:18 (adskflex) EXTERNAL FILTERS are OFF
10:35:18 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:18 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:18 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:18 (lmgrd) Since this is an unknown status, license server
10:35:18 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:18 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:18 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 558)
10:35:18 (adskflex) Unable to initialize access to trusted storage: 1
10:35:18 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:18 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 559)
10:35:19 (adskflex) Server started on 127.0.0.1 for:
10:35:19 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:19 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:19 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:19 (adskflex) 85737SMKMACWG_2012_0F)
10:35:19 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:19 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:19 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:19 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:19 (adskflex) EXTERNAL FILTERS are OFF
10:35:19 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:19 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:19 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:19 (lmgrd) Since this is an unknown status, license server
10:35:19 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:19 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:19 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 560)
10:35:19 (adskflex) Unable to initialize access to trusted storage: 1
10:35:19 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:19 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 561)
10:35:20 (adskflex) Server started on 127.0.0.1 for:
10:35:20 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:20 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:20 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:20 (adskflex) 85737SMKMACWG_2012_0F)
10:35:20 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:20 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:20 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:20 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:20 (adskflex) EXTERNAL FILTERS are OFF
10:35:20 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:20 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:20 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:20 (lmgrd) Since this is an unknown status, license server
10:35:20 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:20 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:20 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 562)
10:35:20 (adskflex) Unable to initialize access to trusted storage: 1
10:35:20 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:20 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 563)
10:35:21 (adskflex) Server started on 127.0.0.1 for:
10:35:21 (adskflex) 85738SMKMAC_F (consisting of: 85937SMKMAC_2013_0F
10:35:21 (adskflex) 85737SMKMAC_2012_0F 85693SMKMAC_2011_0F)
10:35:21 (adskflex) 85737SMKMACWG_F (consisting of: 85937SMKMACWG_2013_0F
10:35:21 (adskflex) 85737SMKMACWG_2012_0F)
10:35:21 (adskflex) 85737SMKMACBRN_F (consisting of: 85937SMKMACBRN_2013_0F
10:35:21 (adskflex) 85737SMKMACBRN_2012_0F 85693SMKMACBRN_2011_0F)
10:35:21 (adskflex) 85738SMKMACWG1_F (consisting of: 85693SMKMACWG1_2011_0F)
10:35:21 (adskflex) 85738SMKMACWG2_F (consisting of: 85693SMKMACWG2_2011_0F)
10:35:21 (adskflex) EXTERNAL FILTERS are OFF
10:35:21 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,7))
10:35:21 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
10:35:21 (lmgrd) adskflex exited with status 37 (Communications error)
10:35:21 (lmgrd) Since this is an unknown status, license server
10:35:21 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:35:21 (lmgrd) Using vendor daemon port 2081 specified in license file
10:35:21 (lmgrd) REStarted adskflex (internet tcp_port 2081 pid 564)
10:35:21 (adskflex) Unable to initialize access to trusted storage: 1
10:35:21 (adskflex) FlexNet Licensing version v11.11.1.1 build 119913 x64_mac10
10:35:21 (lmgrd) Please correct problem and restart daemons
I've been tried to change ports from 2080 to 2081 and server port 27000 to 27100,27009 and no results
PLEASE HELP
I've got mac 2010 with
OS X 10.8.5
Hi Chris.
Have you tried restarting your Mac?
Is the license server installed on the same computer as Smoke, or on a different computer?
Open the License Server Configurator app and look at the license key text. Does the SERVER line contain "localhost" or the actual host name of your server? If it's the actual host name, try changing it to "localhost" and restart the server.
Robert.
Looks like it cannot communicate with lmgrd. This typically takes port 27000 by default unless you specify otherwise in the LIC file (or if 27000 is already in use.) Open ports 27000-27009 in the firewall to make sure it can connect to itself properly (and by IPv4.)
