Installation & Licensing
FlexLM under UNIX - how come ACAD can´t work with it?
10 REPLIES 10
Message 1 of 11
640 Views, 10 Replies
Autodesk switched from ADLM to the FLEXLM license thingy because its the most popular license system.. how come they support License servers running under different OS´s than MS? Is there a work around how I can use the ADESK licenses under an UNIX/OS like linux?
a customer is very angry about the need to install an NT server into his only Unixservers enviroment.. and is of course already using FlexLM on unix to serv 5 other products.. now he heard ACAD uses FlexLM.. and naturally wants to use the already running FlexLM system in his network!!!! Hope Somebody can help!! URGENT!!! THX alot!
10 REPLIES 10
Message 2 of 11
Hi Florian,
There is no way to get the UNIX version of FlexLM to give out licenses to
Autodesk products.
Under the Windows version of Flex, the main Service running all the time on
the server is called "LMGRD.EXE". I believe the Unix version has a
counterpart for this service.
Here is the problem: As I understand, each vendor that uses Flex must
write their own service that understands how to deal with requests for it's
own licenses. Our Windows version is called "ADSKFLEX.EXE". LMGRD
listens for license requests from client workstations, then asks
adskflex.exe how to handle them. We would have to write a UNIX version of
this service for it to work correctly. I'm pretty sure we will not be
supporting the UNIX FlexLM tool in the future.
Keep in mind that we support running FlexLM on an NT/WIN2k/XP Workstation as
long as there are no more than 10 users. The "Server" version of windows
is only required for use with more than 10 users. This is Microsoft's
requirement, not ours. See D:\I386\EULA.TXT on an NT/2k install cd for all
of the Microsoft legal mumbo-jumbo you can handle. 🙂
Chris
"florian_lamberty" wrote in message
news:f0d112f.-1@WebX.maYIadrTaRb...
Message 3 of 11
Under Windows Workstation, you cab use UDP protocol with no limitation of
users.
If this can help you, this is in the documentation.
Why don't you say it Chris?
"Chris Dodge [Americas Product Support]" a
écrit dans le message news:
AADEF19C63736E864BF1C73F8A17223F@in.WebX.maYIadrTaRb...
> Hi Florian,
> Autodesk products.
on
it's
of
as
all
> Chris
running
ADESK
unix
Message 4 of 11
Chris's point, I think, was that MS's licensing allows only 10 simultaneous
connections to a workstation. If I undestand it all correectly (and MS
licensing issues are pretty arcane, so I may very well be getting this mixed
up) even if you find a way to get around the 10 user limit technically, by
using udp, or anything else that you can get to work, then you would be in
violation of MS's EULA.
"franck Hervet" wrote in message
news:EAA7F85930480FA9569D11D28117FF68@in.WebX.maYIadrTaRb...
> users.
a
> > Hi Florian,
to
> > Autodesk products.
> on
> it's
> of
Workstation
> as
windows
> all
> > Chris
the
> running
> ADESK
his
> unix
Message 5 of 11
MS's EULA only limits TCP connections. It does not limit UDP connections.
So if you wanted to use UDP for the AutoCAD to communicate with the lic
server you could you the workstation version for more than 10 connections.
Kevin Nehls
"Charles Prettyman" wrote in message
news:4E181E00C3B71A50B2F4149189745A16@in.WebX.maYIadrTaRb...
simultaneous
mixed
Message 6 of 11
Here is a section of the Windows 2000 EULA. It does not mention TCP or UDP
anywhere in the document:
C:\WINNT\SYSTEM32\EULA.TXT:
" * Installation and use. You may install, use, access,
display and run one copy of the Product on a single
computer, such as a workstation, terminal or other device
("Workstation Computer"). A "License Pack" allows you to
install, use, access, display and run additional copies of
the Product up to the number of "Licensed Copies" specified
above. The Product may not be used by more than two (2)
processors at any one time on any single Workstation
Computer. You may permit a maximum of ten (10) computers or
other electronic devices (each a "Device") to connect to the
Workstation Computer to utilize the services of the Product
solely for file and print services, internet information
services, and remote access (including connection sharing
and telephony services). The ten connection maximum includes
any indirect connections made through "multiplexing" or
other software or hardware which pools or aggregates
connections. You may not use the Product to permit any
Device to use, access, display or run other executable
software residing on the Workstation Computer, nor may you
permit any Device to display the Product's user interface,
unless the Device has a separate license for the Product. "
So... I know I've seen UDP referred to as a "Connectionless protocol"
before, but can you definitively say that Microsoft allows more than 10 UDP
connections on Workstations? If you use "NETSTAT -a" in a Command window,
it will list TCP -and- UDP "Active Connections".
Yes, technically you can bypass the 10 limit connection by switching Flex
over to UDP. I'm just not quite sure we can 'officially' suggest that yet.
Chris
"Kevin Nehls" wrote in message
news:6C22A41F340B4B3D3AA3E1716ED1E2D7@in.WebX.maYIadrTaRb...
> Kevin Nehls
> simultaneous
> mixed
by
in
Message 7 of 11
Hi Chris,
I have a document from Autodesk (English Powerpoint version) that say you
can do it with UDP with no limit on the connections! (I give you a copy of
this in a next message)
And now you talk about Microsoft EULA?
What i say to my client that want use UDP with no limit because i have send
us this Powerpoint.
Don't you have made a test with this protocol?
Best regards.
Chris Dodge [Americas Product Support] a
écrit dans le message :
8669F4BC461BFB731359511312FA7DE8@in.WebX.maYIadrTaRb...
UDP
UDP
window,
yet.
> Chris
connections.
connections.
> > Kevin Nehls
> > simultaneous
MS
> > mixed
technically,
> by
be
> in
Message 8 of 11
You don't need to install an NT/2000 server.
Just install it on one of the client machines.  Don't make a mountain out
of a mole-hill.  Lots of people do this.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Autodesk
UNIX/OS like linux?
alot!
Message 9 of 11
Then when that person shuts down their computer for the night, they call in
sick, or their computer crashes everyone looses their licenses.
I strongly suggest that you have at least one standalone NT / W2K
workstation for your lic server. If you have a lot of users then spend
$1000-1500 for a low end Win2K server and use that as your lic server,
although you may have to purchase additional CALs to access the server.
Kevin Nehls
"AK" wrote in message
news:0220CC4AAEEE0C8AF89C6890DEBB1202@in.WebX.maYIadrTaRb...
> You don't need to install an NT/2000 server. Just install it on one of
the client machines. Don't make a mountain out of a mole-hill. Lots of
people do this.
Message 10 of 11
Chris
bear in mind that I am neiother a lawyer, or a person who grasps Microsofts
corporte thought process, but, this clip is interesting:
If I read that, in my simple minded, normal person sort of way, I understand
it to mean that you cannot run any sort of server application on the
workstation of Windows 2000, which would mean that the license manager, even
though it works perfectly well on a workstation, is technically a violation.
That EULA lets you share data, internet access and printing, but that's it.
wrote in message
news:8669F4BC461BFB731359511312FA7DE8@in.WebX.maYIadrTaRb...
UDP
UDP
window,
yet.
> Chris
connections.
connections.
> > Kevin Nehls
> > simultaneous
MS
> > mixed
technically,
> by
be
> in
Message 11 of 11
Yes, but all of those are server type applications. I'd bet that even MS's
big time lawyers would have an extremely hard time justifying most of their
EULA in court.
This comes down to that same part of MS's EULA that makes people think that
it's illegal to run VNC or PcAnywhere on NT, Win2K, or WinXP (home or pro).
Which I don't think it is. Plus, if MS ever brought a lawsuit against
someone that was using one of those products they'd be taking a major hit in
the monopoly arena.
Even AutoCAD's EULA has some "fuzzy" wording that makes it a violation to
run Acad in a terminal server environment, but they'd still have a really
hard time enforcing it. 1) Because of the way it's worded and 2) as long as
you could prove that you only had 1 person for each license accessing the
server, there isn't much they can do. Why would they want to, they've
already gotten their money?
Kevin Nehls
news:3725B9B88B62769545B558DF46A70F89@in.WebX.maYIadrTaRb...
it.
Administrator Productivity
