Installation & Licensing
206 Views, 5 Replies
FlexLM licence
I am a system intergrater and we bought FlexLm with 17 lic's Acad2002.
But now evry time a start AutoCAD 2002 it askes where can I find the licence
server.
When I fill in the server name he will find it and AutoCAD 2002 will work.
But when I quit AutoCAD and restart it again it still askes for the server.
Can anyone help me to solve this problem
Greetings Frits Blankenzee
5 REPLIES 5
You need to create a licpath.lic file in the autocad directory on each
client.
It should read like this, with you filling in the correct information
SERVER
USE_SERVER
This file should have been created during installation based on what you
filled in when you created the deployment location.
HTH
Kevin Nehls
Hi Kevin.\,
Thanx for your remark but I had that file in my AutoCAD dir. But it still
askes at my place for the server,.
When I find the server AutoCAD wil run perfectly. Thats why I send this
message
"Kevin Nehls" schreef in bericht
news:AF12807976A37A5A293DD561E8BD4404@in.WebX.maYIadrTaRb...
> client.
> SERVER
> USE_SERVER
> HTH
> Kevin Nehls
what does the file look like? (Open it in Notepad) This is the one I am
using:
SERVER MONSTERI 00d0b7e3f9a7
USE_SERVER
Where MONSTERI is the Host name of the server and 00d0b7e3f9a7 is the
ethernet address of the networkadapter on the server. A common mistake is to
have the IP-address of the server in the file in stead of the ethernet
address.
Another way to test this is to set the following environment variable on the
workstation:
LM_LICENSE_FILE and give it a value that is equal to the hostname of the
server.
"Frits Blankenzee" wrote in message
news:3664CF0881F9BBE10AE40202341400E3@in.WebX.maYIadrTaRb...
> Hi Kevin.\,
> message
> > client.
> > SERVER
> > USE_SERVER
> > HTH
> > Kevin Nehls
I'd also check to make sure the MAC address and the server name is correct.
I typoed my server name when setting up my deployment and got the same
message.
Kevin Nehls
Many Many Thanx.
This will do the trick....
It has been stopped. And AutoCAD Works perfectly..
Again Many thanx.
"Petri Ahava" schreef in bericht
news:4CF7413476883E48DD6B6485977210EF@in.WebX.maYIadrTaRb...
> Hi,
> using:
> USE_SERVER
to
> address.
the
> workstation:
> server.
> > Hi Kevin.\,
still
> > message
> > > client.
> > > SERVER
> > > USE_SERVER
you
> > > HTH
> > > Kevin Nehls
Administrator Productivity
