Thanks, I'll give it a try tonight when the place isn't crawling with active
AutoCAD users.
Mark McDonough
Sasaki Associates
http://www.sasaki.com
"Efim Tetelman (Autodesk, Inc)" wrote in
message news:414087af$1_2@newsprd01...
> Hi Mark,
> the easiest way is to stop service and replace installed lmgrd.exe,
> lmtools.exe and lmutil.exe with the 9.2 versions, then start your service
> again.
> Hope this helps.
> Efim
> "Mark McDonough" wrote in message
> news:414075d0_3@newsprd01...
> > I'm running FlexLM 8.3 to serve up approximately 150 Autodesk products
> > (AutoCAD 2004, Land Desktop, Civil, Raster Design, Map, VIZ 2005, etc).
> Now
> > I want to add four Revit 6.1 licenses, and learned I must upgrade the
> FlexLM
> > to 9.2. I was told by our local reseller support techie, that I can
> install
> > FlexLM 9.2.2 in situ, right on top of the FlexLM 8.3, and it'll upgrade
it
> > to 9.2.2 without problems.
> > Reading in this NG, it seems that there are other more cautious
> > recommendations, such as backing up the previous FlexLM executables and
> > stopping the service before attempting 9.2. Any suggestions?
> > I have some trepidation about this because of a similar scenario, on a
> > different license server box for our ESRI ArcGIS licenses, that also
uses
> > FlexLM (an older 7.0b version), and when I attempt the upgrade there
> > (service stopped before installation), it toasted the setup completely,
> and
> > I had to reinstall the previous version.
> > Mark McDonough
> > Sasaki Associates
