• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    FlexLM 11.10. build 95001 x64 returns no license.
    290 Views, 5 Replies
    01-16-2013 05:49 AM
    I have a 10-seat license and just got it verified with http://www.licenseparser.com.
    The FlexLM runs as a service on a Win7 64 machine.
    The clients are Win7 64 machines.
    If I click Server Status it returns me this:
    Status
    Flexible License Manager status on Wed 1/16/2013 13:54
    [Detecting lmgrd processes...]
    License server status: 27000@XXXXX
        License file(s) on XXXXXX: C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic:
      XXXXXX: license server UP (MASTER) v11.10
    Vendor daemon status (on XXXXXX):
      adskflex: UP v11.10
    Feature usage info:
    Users of 85788BDSADV_F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    Users of 85948BDSADV_2013_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    Users of 85788BDSADV_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    Users of 85778RSAPRO_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    Users of 85882INFMDR_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    Users of 85793REVSYP_2012_0F:  (Total of 10 licenses issued;  Total of 0 licenses in use) ...
     Server Diags:
    Diagnostics
    FLEXnet diagnostics on Wed 1/16/2013 13:53
    License file: C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic
    "85788BDSADV_F" v1.000, vendor: adskflex
      License server: XXXXXX
      floating license  starts: 1-jan-1990,  no expiration date
      Requests from the same USER/HOST do not consume a new license
    This license cannot be checked out because:
    A PACKAGE component must be specified.
    Feature:       85788BDSADV_F
    License path:  C:\Program Files\Autodesk Network License Manager\lice\BDSADV2013enlicense.lic;
    FLEXnet Licensing error:-125,147
    For further information, refer to the FLEXnet Licensing documentation,
    available at "www.flexerasoftware.com".
    "85948BDSADV_2013_0F" v1.000, vendor: adskflex
      License server: XXXXXXX
    This license can be checked out
    "85788BDSADV_2012_0F" v1.000, vendor: adskflex
    And so on...
    There I can only see one error. But accorting to http://forums.autodesk.com/t5/Installation-Licensing/FLEXnet-Licensing-error-125-147/td-p/2834003 it can be ignored.
    Browsing to http://XXXXX:27000 gives me Wê-60Wê-60Wê-60Wê-60Wê-60
    When I start ACAD it returns
    A valid license could not be obtained by the network license manager.
    Error [-15.570.0]
    All these solutions from http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2012-License-Error-15-570-0/m-p/3075606... did not work.
    FLEXnet is the most frustrating software ever!
    Any tricks/hints I should know?
    TIA
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: FlexLM 11.10. build 95001 x64 returns no license.
    01-16-2013 05:51 AM in reply to: jonathan.quartier
    can the computer ping the license server by name?
    Active Member
    01-16-2013 06:47 AM in reply to: DarrenP
    Yes. The host answers....
    *Expert Elite*
    DarrenP
    01-16-2013 06:49 AM in reply to: jonathan.quartier
    how about on the license server
    when you ping its self to you get an Ipv 4 address or a ipv6 address?
    *Expert Elite*
    TravisNave
    01-16-2013 10:28 AM in reply to: jonathan.quartier
    Darren is right, it has to be IPv4 and the correct one at that.
    Also, note that Windows 7 has a concurrent connection limitation as well.  Depending on your version, you have a limitation of up to 20 concurrent sessions.  Server does not have this limitation.
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    01-16-2013 11:06 PM in reply to: jonathan.quartier
    You did http://XXXXX:27000  but did you also do http://XXXXX:2080 ?  It might also be worth testing ports 27001 - 27009.  Basically the worstation needs to be able to communicate with the licence server through ports 2080 and 27000 - 27009.
    I usually recommend doing a telnet to the server through those ports, however you would need to enable the telnet client on the workstation.
    As has already been suggested is the IPV4/IPV issue
    On the server if start the dos command prompt and do an ipconfig /all and see if you can find any lrefernce to IPV6 then you should either disable it
    http://support.microsoft.com/kb/929852
    OR
    install the IPV6 version of LMTools
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10976858&linkID=13140816
    _____________________________
    A2K Technologies Support Team
    www.a2ktechnologies.com.au
