I am currently installing the license manager for the AutoCAD 2007 & Revit 9. The license manager is upgraded to v. 10.8 & currently running Autodesk2004 without a problem. The server is running Windows SBS 2003.
The license manager is not working for these new programs the Sam Lite program will not load. Any assistance you might be able to offer would be very much appreciated. Thank you in advance.
When running the latest version of Samreport.exe from the server desktop produces this error: A suitable JVM could not be found. Please run the program again using the option -is:javahome
& checking the server status of the license manager produces this result:
License server status: 27001@server01
License file(s) on server01: C:\Nlm2007\License\REVITS9server01.lic:
server01: license server UP (MASTER) v10.8
Vendor daemon status (on server01):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Feature: 43200ARCHDESK_2004_0F
Vendor:Host: server01
License path: 27000@server01
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Here is the server log:
15:33:35 (lmgrd) ----------------------------------------------- 15:33:35 (lmgrd) Please Note: 15:33:35 (lmgrd) 15:33:35 (lmgrd) This log is intended for debug purposes only. 15:33:35 (lmgrd) In order to capture accurate license 15:33:35 (lmgrd) usage data into an organized repository, 15:33:35 (lmgrd) please enable report logging. Use Macrovision's 15:33:35 (lmgrd) software license administration solution, 15:33:35 (lmgrd) FLEXnet Manager, to readily gain visibility 15:33:35 (lmgrd) into license usage data and to create 15:33:35 (lmgrd) insightful reports on critical information like 15:33:35 (lmgrd) license availability and usage. FLEXnet Manager 15:33:35 (lmgrd) can be fully automated to run these reports on 15:33:35 (lmgrd) schedule and can be used to track license 15:33:35 (lmgrd) servers and usage across a heterogeneous 15:33:35 (lmgrd) network of servers including Windows NT, Linux 15:33:35 (lmgrd) and UNIX. Contact Macrovision at 15:33:35 (lmgrd) www.macrovision.com for more details on how to 15:33:35 (lmgrd) obtain an evaluation copy of FLEXnet Manager 15:33:35 (lmgrd) for your enterprise. 15:33:35 (lmgrd) 15:33:35 (lmgrd) ----------------------------------------------- 15:33:35 (lmgrd) 15:33:35 (lmgrd) 15:33:35 (lmgrd) pid 2424 15:33:35 (lmgrd) Detecting other license server manager (lmgrd) processes... 15:33:35 (lmgrd) Done rereading 15:33:35 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on SERVER01 (IBM PC) (1/7/2007) 15:33:35 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved. 15:33:35 (lmgrd) US Patents 5,390,297 and 5,671,412. 15:33:35 (lmgrd) World Wide Web: http://www.macrovision.com 15:33:35 (lmgrd) License file(s): C:\Nlm2007\License\341-53809174.lic 15:33:35 (lmgrd) lmgrd tcp-port 27000 15:33:35 (lmgrd) Starting vendor daemons ... 15:33:35 (lmgrd) Starting vendor daemon at port 2080 15:33:35 (lmgrd) Using vendor daemon port 2080 specified in license file 15:33:35 (lmgrd) Started adskflex (pid 2540) 15:33:35 (adskflex) FLEXnet Licensing version v10.8.0 build 18869 15:33:35 (adskflex) Server started on SERVER01 for: 43200ARCHDESK_2004_0F 15:33:35 (lmgrd) adskflex using TCP-port 2080 15:36:06 (adskflex) TCP_NODELAY NOT enabled 15:54:27 (adskflex) OUT: "43200ARCHDESK_2004_0F"
(This continues to show Adesk 2004 license which are not a problem.)
