The only way I can get Civil3d to read the NLM server is to completely turn off the firewall at the server.
I tried to add LMTOOLS to the exception list and I added the port as well to the exceptions and it will not work unless turned off.
There has to be a way to allow this. The server O.S. is win2003server.
if anyone knows anything the info would be greatly appreciated.
Andy
Solved by david.lau. Go to Solution.
Can you check out this post?
