• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Company, The Daiker
    File will not load
    204 Views, 6 Replies
    09-22-1999 08:21 AM
    In an attempt to load a drawing from tne server, we experienced an
    INTERNAL ERROR: !dbapicls.cc5
    This was a normal loading attemp.
    It repeated during a "recover" attempt.
    The same drawing can be opened from the server without any errors.
    Any suggestions?
    Please use plain text.
    Re: File will not load
    09-22-1999 08:29 AM in reply to: *Company, The Daiker
    > Any suggestions?
    Also we are using Wdws 98 as our network system and NETBUI as the
    Protocol
    *[Autodesk], jerry milana
    Re:
    09-22-1999 11:51 AM in reply to: *Company, The Daiker
    Update the drivers for your network adapters on all of your Windows 98
    systems. Even if these are new systems and/or network adapters, it is
    likely the hardware has been packaged with the latest updates. It is
    also a good idea to verify that the adapters you are using are supported
    on Windows 98.
    Jerry Milana,
    Autodesk Product Support
    > > Any suggestions?
    > Protocol
    Re:
    09-23-1999 02:41 PM in reply to: *Company, The Daiker
    > on Windows 98.
    > Jerry Milana,
    > > > Any suggestions?
    > > Protocol
    Thanks for the suggestion, but updating the adapter drivers did not
    solve the error message problem. Any other suggestions?
    Re:
    09-23-1999 02:52 PM in reply to: *Company, The Daiker
    > > on Windows 98.
    > > Jerry Milana,
    > > > > Any suggestions?
    > > > Protocol
    Also, the adapter card is an SN3200, PCI card.
    We reloaded autocad on the client machine twice, thinking it was a bug
    or bad load, but the results were the same. All the other machines can
    load this same file without an error message. We installed a new
    adapter as well, hoping this would do the trick! "No Luck". The error
    leads me to believe that the specific client machine software is
    reading a corrupt signature in the file or the specific client machine
    software is not communicating. I will try reloading WDWS 98 now. Help
    me if you can!
    Re:
    09-23-1999 03:19 PM in reply to: *Company, The Daiker
    I am not familiar with the SN3200 NIC. I looked up that number on the Microsoft
    Windows compatibility list at http://www.microsoft.com/hcl/default.asp and do
    not come up with a result. Did you try two different types of cards with
    associated drivers or just another of the same type? If two adapters still gave
    the same problem, then I would reinstall the operating system. Did this
    computer come with Windows 98? Check at the above mentioned WEB site that your
    system and adapter is Windows 98 Compliant.
    Jerry
    > > > on Windows 98.
    > > > Jerry Milana,
    > > > > > Any suggestions?
    > > > > Protocol
    > me if you can!
    Re:
    09-24-1999 08:46 AM in reply to: *Company, The Daiker
    > Jerry
    > > > > on Windows 98.
    > > > > Jerry Milana,
    > > > > > > Any suggestions?
    > > > > > Protocol
    > > me if you can!
