Installation & Licensing
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Company, The Daiker
File will not load
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
203 Views, 6 Replies
09-22-1999 08:21 AM
In an attempt to load a drawing from tne server, we experienced an
INTERNAL ERROR: !dbapicls.cc5
This was a normal loading attemp.
It repeated during a "recover" attempt.
The same drawing can be opened from the server without any errors.
Any suggestions?
Any suggestions?
Re: File will not load
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-22-1999 08:29 AM in reply to:
> Any suggestions?
Also we are using Wdws 98 as our network system and NETBUI as the
Protocol
> Any suggestions?
Protocol
*[Autodesk], jerry milana
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-22-1999 11:51 AM in reply to:
Update the drivers for your network adapters on all of your Windows 98
systems. Even if these are new systems and/or network adapters, it is
likely the hardware has been packaged with the latest updates. It is
also a good idea to verify that the adapters you are using are supported
on Windows 98.
Jerry Milana,
Autodesk Product Support
> > Any suggestions?
> Protocol
on Windows 98.
Jerry Milana,
> > Any suggestions?
> Protocol
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-23-1999 02:41 PM in reply to:
> on Windows 98.
> Jerry Milana,
> > > Any suggestions?
> > Protocol
Thanks for the suggestion, but updating the adapter drivers did not
solve the error message problem. Any other suggestions?
> on Windows 98.
> Jerry Milana,
> > > Any suggestions?
> > Protocol
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-23-1999 02:52 PM in reply to:
> > on Windows 98.
> > Jerry Milana,
> > > > Any suggestions?
> > > Protocol
Also, the adapter card is an SN3200, PCI card.
We reloaded autocad on the client machine twice, thinking it was a bug
or bad load, but the results were the same. All the other machines can
load this same file without an error message. We installed a new
adapter as well, hoping this would do the trick! "No Luck". The error
leads me to believe that the specific client machine software is
reading a corrupt signature in the file or the specific client machine
software is not communicating. I will try reloading WDWS 98 now. Help
me if you can!
> > on Windows 98.
> > Jerry Milana,
> > > > Any suggestions?
> > > Protocol
me if you can!
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-23-1999 03:19 PM in reply to:
I am not familiar with the SN3200 NIC. I looked up that number on the Microsoft
Windows compatibility list at http://www.microsoft.com/hcl/default.asp and do
not come up with a result. Did you try two different types of cards with
associated drivers or just another of the same type? If two adapters still gave
the same problem, then I would reinstall the operating system. Did this
computer come with Windows 98? Check at the above mentioned WEB site that your
system and adapter is Windows 98 Compliant.
Jerry
> > > on Windows 98.
> > > Jerry Milana,
> > > > > Any suggestions?
> > > > Protocol
> me if you can!
Jerry
> > > on Windows 98.
> > > Jerry Milana,
> > > > > Any suggestions?
> > > > Protocol
> me if you can!
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-24-1999 08:46 AM in reply to:
> Jerry
> > > > on Windows 98.
> > > > Jerry Milana,
> > > > > > Any suggestions?
> > > > > Protocol
> > me if you can!
> Jerry
> > > > on Windows 98.
> > > > Jerry Milana,
> > > > > > Any suggestions?
> > > > > Protocol
> > me if you can!
