Guys,
It has been several days now since I have been attempting to install Autodesk Product Design Suite 2013 on a fresh installation of Windows 7 Enterprise N. Throghout the installation I have recieved several errors all labled 1603 wich are just general erors. usuall restarting the installer correctes the problem. However what is weird is some of the programs that install run flawlessly. Others crash reproting this same error Fatal Error unhandled c0000094h exception at f03c2706h.
Now I have looked up and down and I can not seem to find any information on this error other than susspect it has something to do with my Graphics cards and their drivers. I have 2 Nvida Quadro K5000 briged in SLI. These are running on an ASUS Z9PE-D16 with 2 Intel Xeon 2660 CPU's Below I listed all the programs that seem to work, followed by the ones that do not.
THESE INSTALLATIONS WORK
Autodesk Product Design Suite Ultimate Launcher 2013
Autodesk Inventor Professional 2013
Inventor Fusion 2013
Navisworks Simulate 2013
Autodesk Vault Basic 2013
Autodesk Design Review 2013
Alias Design 2013
Autodesk 3ds Max Design 2013 64-bit
Autodesk Mudbox 2013 64-bit
SketchBook Designer 2013
THESE INSTALLATIONS DO NOT WORK
Autodesk Showcase 2013 (64-bit)
AutoCAD 2013 - English
DWG TrueView 2013 - (Runs until you attempt to open a file)
AutoCAD Mechanical 2013 - English
AutoCAD Electrical 2013
Again all these reprot the exact same error Fatal Error unhandled c0000094h exception at f03c2706h. I have cleaned up, uninstalled and reinstalled .NET. Same thing with my graphics drivers and I still recieve the same error. Does anyone have any suggestions?
And before I go I would like to just clarify something. The Autodesk Product Design Package Ultimate is said to include Standard AutoCAD 2013. However it doesn't install it. I had to donwload the trial AutoCAD 2013 from Autodesk.com and use my serial with a different product key. Then it reports my serial is invalid. How do I get just stanard AutoCAD?
Thaks for your help guys!
