• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *T., Scott
    Fatal Error: Security system . .
    110 Views, 5 Replies
    01-15-2001 12:21 AM
    We have five floating licenses on our NT Server network. The pc's have NT
    > > Workstation and are PII500 with 256MB RAM and 512MB swap file. 8GB of
    > free
    > > space on HD. We are running AutoCAD R14.
    > > When one of my users opens AutoCad, he receives the error "Fatal
    > > Error:smileyfrustrated:ecurity system (hardware lock or network license) is not
    > functioning
    > > or is improperly installed". When I run the ADLM it shows me that only
    3
    > of
    > > the 5 licenses are in use. This came from nowhere and happened all of a
    > > sudden. Anyone know what could be causing this?
    Please use plain text.
    *Support], Anthony Governanti [Autodesk
    Re: Fatal Error: Security system . .
    01-15-2001 01:13 AM in reply to: *T., Scott
    Go to the workstations, and browse to the license server through Windows
    Explorer. Browse to the ADLM directory and double click on the winquery.exe
    application. Click on the Servers button, and see what it reports. If it
    does not see the hostname of the license server, then the workstation has
    lost connection with it. You need to check the Acadserver variable; click
    on the properties button, and see if the acadserver is set to anything. You
    can force the Workstations to see the license server by setting this
    variable to the hostname of the server. There is a solution on our
    Knowledge Base website at http://support.autodesk.com/ViewAnswerworks.asp
    enter the question "How do I set the acadserver variable in windows NT?" and
    the solution TS16236 will be the first one to come up.
    This issue wouldn't just happen for no reason, something had to change on
    either the License server, or the Workstations themselves, check with the
    users of those machines, or the Network Admin (if it isn't you) to see if
    anything has changed.
    Anthony Governanti [Autodesk Support]
    AEC Product Support Americas
    WW Support & Services, Autodesk
    *T., Scott
    Re:
    01-15-2001 01:29 AM in reply to: *T., Scott
    The user can see the hostname of the license server and status is Active.
    He can also view the clients that are currently online. The only thing that
    changed was I have added ISDN internet access. Everything else is the same.
    He still accesses the server in the same way and has no problem getting to
    anything else on the network.
    "Anthony Governanti [Autodesk Support]"
    wrote in message
    news:7D9EED8AC44690D257F6978425B66C64@in.WebX.SaUCah8kaAW...
    winquery.exe
    You
    and
    Re:
    01-15-2001 04:54 AM in reply to: *T., Scott
    Did you check the Acadserver settings?
    *martin, jason
    Re:
    01-15-2001 06:52 AM in reply to: *T., Scott
    Is the ISDN access point on the adlm server?? Does it require some other type of network
    interface with IP protocol installed??? adlm on a server with more than 1 network card
    doesn't work (correctly).
    jason martin
    frankfurt-short-bruza
    "Scott T." wrote in message
    news:0C137BED9A7B526B82B8643621097A13@in.WebX.SaUCah8kaAW...
    *T., Scott
    Re:
    01-15-2001 06:57 AM in reply to: *T., Scott
    No, the ISDN access point is not on the ADLM server, it's plugged directly
    into the hub. No, your next questions do not apply.
    "jason martin" wrote in message
    news:smileyvery-happy:4770C502CD49F85F134A6B47EA5A61C@in.WebX.SaUCah8kaAW...
    type of network
    network card
    > jason martin
    Active.
    that
    same.
    to
