• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Purdy, Steve
    Fatal Error: Security system is not functioning or is improperly installed
    141 Views, 4 Replies
    02-28-2001 04:31 AM
    We have a network installation of AutoCad Map 3. The machine that hosts the
    license manager and a workstation were recently upgraded to Windows 2000.
    The license manager and clients were re-installed, and the LM runs fine, and
    a second workstation running Windows 95 runs the client without incident.
    But the Win2000 workstation won't run the client after installation, giving
    the message "Fatal Error: Security system is not functioning or is
    improperly installed".
    I reviewed the help document on the website and tried several things,
    without success:
    I can ping the host from the workstation.
    The system dates and times are the same.
    I tried setting the ACADSERVER to the host name, but it doesn't
    "stick"--after I close the command prompt window and reopen it, the
    ACADSERVER variable is gone. Don't know what that means. Regardless, it
    doesn't correct the problem.
    The host is recognizing the workstation. This line appears in the log file:
    01-Feb-28 09:37:46: user@workstation [0]: Missed packet: Bad file
    descriptor.
    Any ideas?
    Steve
    Please use plain text.
    *martin, jason
    Re: Fatal Error: Security system is not functioning or is improperly installed
    02-28-2001 05:47 AM in reply to: *Purdy, Steve
    Steve -
    Have you updated adesksys.dll? Check out
    http://support01.autodesk.com/knowledgebase/html/157553.htm (watch for wrapping in the
    link).
    You can't set a system variable at the command prompt. It only lasts for that session of
    command.exe. To set the variable (if you must) go to start / settings / control panel /
    system / Advanced / Environment Variables and set it in the system variables box.
    hth
    jason martin
    frankfurt-short-bruza
    "Steve Purdy" wrote in message
    news:7842C880017DFC3941076E2D7DDA3D4C@in.WebX.maYIadrTaRb...
    > without success:
    > descriptor.
    > Any ideas?
    > Steve
    *Purdy, Steve
    Re:
    02-28-2001 06:41 AM in reply to: *Purdy, Steve
    Thanks, Jason. Reading the installation instructions for adesksys.dll, it
    says that if the existing file doesn't have exactly 90112 bytes, not to
    proceed. Mine has 85504, so I guess that's out.
    I changed the ACADSERVER variable in the manner you suggested, and still no
    go.
    Thanks anyway.
    Steve
    "jason martin" wrote in message
    news:7030544CE8677F9B388A2AFB8C3DAC46@in.WebX.maYIadrTaRb...
    > Steve -
    wrapping in the
    > link).
    that session of
    control panel /
    variables box.
    > hth
    > jason martin
    the
    2000.
    and
    incident.
    giving
    > > without success:
    it
    file:
    > > descriptor.
    > > Any ideas?
    > > Steve
    *martin, jason
    Re:
    02-28-2001 10:17 AM in reply to: *Purdy, Steve
    Do me a favor. Rename the existing adesksys.dll to adesksysdll.old and put
    the new one in there. Let me know if it works. If it doesn't you can
    always put the old one back. I ran into the same problem. According to the
    instructions I shouldn't have replaced the old adesksys.dll, but it wasn't
    working so I replaced it anyway and it worked fine.
    hth
    jason martin
    Steve Purdy wrote in message
    news:6D8BF5E0360AF1C5DAB1FAD2D4311837@in.WebX.maYIadrTaRb...
    no
    > go.
    > Thanks anyway.
    > Steve
    > > Steve -
    > wrapping in the
    > > link).
    for
    > that session of
    > control panel /
    > variables box.
    > > hth
    > > jason martin
    hosts
    > the
    > 2000.
    fine,
    > and
    > incident.
    > giving
    > > > without success:
    > it
    > file:
    > > > descriptor.
    > > > Any ideas?
    > > > Steve
    *Purdy, Steve
    Re:
    03-01-2001 01:49 AM in reply to: *Purdy, Steve
    Thank you thank you thank you! It worked!
    Steve
    news:81A01D5645ABD488080E54E5AEB7B160@in.WebX.maYIadrTaRb...
    put
    the
    > hth
    > jason martin
    it
    > no
    > > go.
    > > Thanks anyway.
    > > Steve
    > > > Steve -
    > > wrapping in the
    > > > link).
    > for
    > > that session of
    > > control panel /
    > > variables box.
    > > > hth
    > > > jason martin
    > hosts
    > > the
    > > 2000.
    > fine,
    > > and
    > > incident.
    > > giving
    things,
    > > > > without success:
    Regardless,
    > > it
    log
    > > file:
    > > > > descriptor.
    > > > > Any ideas?
    > > > > Steve
