Installation & Licensing
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*T., Scott
Fatal Error: Security System. . .
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
116 Views, 4 Replies
01-15-2001 06:13 AM
We have five floating licenses on our NT Server network. The pc's have NT
> > Workstation and are PII500 with 256MB RAM and 512MB swap file. 8GB of
> free space on HD. We are running AutoCAD R14.
> > When one of my users opens AutoCad, he receives the error "Fatal
> > Error
ecurity system (hardware lock or network license) is not
> functioning or is improperly installed". When I run the ADLM from his
computer, it shows me that only 3 of the 5 licenses are in use. This came
from nowhere and happened all of a sudden. Anyone know what could be
causing this?
> > Error
causing this?
*McKenzie, Kathy
Re: Fatal Error: Security System. . .
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-15-2001 09:22 PM in reply to:
*T., Scott
Scott,
I realize that this may seem too simple of a reply, but this happened
to one of our users last week. He had a network hickup and his
machine lost its connection with the server temporarily. I tried
everything that has been suggested to you. I overlooked the simplest
scenario.
Check the date and the time on the problem computer. On our machine,
the date had moved forward 2 days and this was what was causing the
problem with the liscense server. Good luck.
Kathy McKenzie
On Mon, 15 Jan 2001 14:13:07 -0800, "Scott T."
wrote:
>We have five floating .....
>causing this?
scenario.
Kathy McKenzie
>causing this?
*milana, jerry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-16-2001 07:28 AM in reply to:
*T., Scott
One other thing that can cause this is your default gateway setting. If the
AdLM server is on a remote segment and the default gateway setting is
pointing to the ISDN connection, the request is going to go out the ISDN
gateway, not to the route to the AdLM server. Make sure that you can ping
the AdLM server by hostname and try setting the ACADSERVER variable using
the @ prefix. Make sure that the variable value is set to the proper case.
This should be lower case with TCP/IP and is NOT the same as the name you
see when browsing the network (that is the netbios name, often the same as
the TCP/IP name but in different case).
jerry milana,
Autodesk Product Support
"Kathy McKenzie" wrote in message
news:7hi86tc1sse68sjhm97eimucs38b9csppv@4ax.com...
> Scott,
> scenario.
> Kathy McKenzie
> >causing this?
jerry milana,
"Kathy McKenzie"
> Scott,
> scenario.
> Kathy McKenzie
> >causing this?
*T., Scott
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-17-2001 05:35 AM in reply to:
*T., Scott
Not sure how to set the ACAD Server variable. I can ping the ADLM server by
hostname. I think your on the right track. It does seem odd that after the
ISDN is installed, all of a sudden he can't connect. Can you tell me more
about setting the ACAD Server variable?
"jerry milana" wrote in message
news:909AF7AFDAB7D299B05B931C4F55B2CB@in.WebX.SaUC ah8kaAW...
the
case.
> jerry milana,
> > Scott,
> > scenario.
> > Kathy McKenzie
> > >causing this?
"jerry milana"
the
case.
> jerry milana,
> "Kathy McKenzie"
> > Scott,
> > scenario.
> > Kathy McKenzie
> > >causing this?
*milana, jerry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-23-2001 06:06 AM in reply to:
*T., Scott
Environment variables are set in different ways, depending on your operating
system. Go to the AutoCAD Product Support knowledgebase search page and
enter ACADSERVER as the keyword. The first three documents to list describe
how to set variables on the different Windows versions.
The knowledgebase page is located at:
http://support01.autodesk.com/ViewAnswerworks.asp
jerry milana,
"Scott T." wrote in message
news:024CA1C08E687D45BA3A873E16B1ECC8@in.WebX.SaUC ah8kaAW...
by
the
> the
ping
using
> case.
you
as
> > jerry milana,
> > > Scott,
> > > scenario.
> > > Kathy McKenzie
> > > >causing this?
jerry milana,
"Scott T."
by
the
> "jerry milana"
> the
ping
using
> case.
you
as
> > jerry milana,
> > "Kathy McKenzie"
> > > Scott,
> > > scenario.
> > > Kathy McKenzie
> > > >causing this?
