Installation & Licensing
ssullivant
294 Views, 5 Replies
Fatal Error Problem
Please help - I'm out of ideas.
Specifics: AutoCad 2000, network version, TCP/IP, NT Server, NT 4 Workstation, Workstation is Dell P3.
Problem: I have successfully installed to several machines, similar workstaion configurations, using a silent install from the deployment directory on the server. However, this last uncooperative workstation won't get it. The installation appears to go normally, yet I get this message when trying to start : "FATAL ERROR: Security system (hardware lock or network license)is not functioning or is improperly installed." I know the ADLM is functioning properly because I can turn around to another machine and run Acad. I don't have a hardware lock. Everything seems to be in order. I'm out of ideas.
5 REPLIES 5
in reply to: ssullivant
Can you ping the ADLM server by name from the bad workstation? And vice
versa?
Tim Quinn
Norfolk Southern
ssullivant wrote in message
news:ef58a5a.-1@WebX.SaUCah8kaAW...
of ideas.
Sounds like a Security issue with the Server to Workstation? Rights?
Privledges?
or double chk on the Protocal (TCP/IP).
-Steve
slozano@thencg.com
"Tim Quinn" wrote in message
news:4C5033CF12F17C8E7D360C9E5DBBC81E@in.WebX.SaUCah8kaAW...
> versa?
> Tim Quinn
> Norfolk Southern
won't
when
out
> of ideas.
ssullivant
Didn't try that. I assumed that since I was able to install from the deployment directory that there would be no communication problems.
ssullivant
Thanks for the input. I'll put in a call to IT on the security idea.
When you find out what's wrong, please let us know.
I got excatly the same problem:-(
Niels
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
idea.
Administrator Productivity
