Installation & Licensing
Member
josborne
Message 1 of 6 (98 Views)
Fatal Error: Network
98 Views, 5 Replies
04-03-2000 10:44 AM
We are receiving the following error:
Fatal Error: A network license error has occurred. AutoC AD is exiting please contact your system admin
The user had been woking on a drawing when this occurrs.
This is using AutoCAD2000 on a NetWare 4.11 LAN. The AutoCAD files have been installed from the LAN to the workstation (i.e. the workstation is going only to the server for licensing).
*josborne
Re: Fatal Error: Network
04-03-2000 10:44 AM in reply to: josborne
*milana, jerry
Message 3 of 6 (98 Views)
04-03-2000 12:26 PM in reply to: josborne
John,
Where are you running AdLM? Do you have more than one network adapter in
the system running AdLM?
Check your adlm.log file, browse the file looking for the user that got the
error at the time the error occured. An error message in the log file may
explain the disconnect.
Jerry Milana,
Autodesk Product Support
"josborne" wrote in message
news:eef6867.-1@WebX.SaUCah8kaAW...
*josborne
Message 4 of 6 (98 Views)
Re:
04-03-2000 12:49 PM in reply to: josborne
Hopefully this information will help:
The file server has one nic, but its an Adaptec ANA 6944ALAN Adapter. It has four ports. Three are in use.
1> IPX frame type 802.2
2> IPX frame type 802.3
3> IP frame type Ethernet_II
The ADLM folder is located on the sys: volume of the file server in the following directory
sys:adlm
adlm.log
00-Apr-03 06:03:29: Autodesk License Manager - Copyright 1997 Elan Computer Group, Inc.
00-Apr-03 06:03:29: ADSKELMD.NLM 5.0.1f started on PPLGR411 (a178f84.000001).
00-Apr-03 06:03:29: Vendor ID = 1a2ccac.
00-Apr-03 06:03:29: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
00-Apr-03 06:03:29: PID = 529203216.
00-Apr-03 06:03:29: Port = 1422.
00-Apr-03 06:03:29: Log file = \ADLM\LOG\ADLM.LOG.
00-Apr-03 06:03:29: Key path = \adlm\key.
00-Apr-03 06:03:29: Keyaccept = 310.
00-Apr-03 06:03:29: Resource file = .
00-Apr-03 06:03:29: Message level = 3.
00-Apr-03 06:03:29: Initialization period = 180 seconds.
00-Apr-03 06:03:29: Peer registered: "PPLGR411" a178f84.000001 a178f84.000001 a178f84.000001 a178f84.000001.
00-Apr-03 06:03:29: Loaded key \adlm\key/150.LIC 3 tokens [MINIKEY].
00-Apr-03 07:44:48: DRUMMLJ@160 [1], 150: SLID-1 1 issued, 1 in use.
00-Apr-03 09:58:32: DRUMMLJ@160 [1], 150: SLID-1 1 returned, 0 in use (used: 0:02:13:44).
00-Apr-03 10:05:19: CRAVENRL@58 [1], 150: SLID-1 1 issued, 1 in use.
00-Apr-03 10:23:16: DRUMMLJ@160 [2], 150: SLID-1 2 issued, 2 in use.
00-Apr-03 10:30:48: OSBORNJR@077 [3], 150: SLID-1 3 issued, 3 in use.
00-Apr-03 10:34:45: CRAVENRL@58 [1], 150: SLID-1 1 returned, 2 in use (used: 0:00:29:26).
00-Apr-03 10:34:46: OSBORNJR@077 [3], 150: SLID-1 3 returned, 1 in use (used: 0:00:03:58).
00-Apr-03 11:02:09: DRUMMLJ@160 [2], 150: SLID-1 2 returned, 0 in use (used: 0:00:38:53).
00-Apr-03 11:02:16: DRUMMLJ@160 [1], 150: SLID-1 1 issued, 1 in use.
00-Apr-03 14:27:01: DRUMMLJ@160 [1]: Zombie.
00-Apr-03 14:27:01: DRUMMLJ@160 [1], 150: SLID-1 1 returned, 0 in use (used: 0:03:24:45).
00-Apr-03 14:27:16: DRUMMLJ@160 (1): Walking dead, pid=16775551 (1/0).
00-Apr-03 14:28:16: DRUMMLJ@160 (1): Walking dead, pid=16775551 (1/0).
00-Apr-03 14:38:01: DRUMMLJ@160 [1], 150: SLID-1 1 issued, 1 in use.
00-Apr-03 14:52:08: DRUMMLJ@160 [1]: Zombie.
00-Apr-03 14:52:08: DRUMMLJ@160 [1], 150: SLID-1 1 returned, 0 in use (used: 0:00:14:07).
00-Apr-03 14:53:03: DRUMMLJ@160 (1): Walking dead, pid=16775551 (1/0).
00-Apr-03 14:54:02: DRUMMLJ@160 (1): Walking dead, pid=16775551 (1/0).
00-Apr-03 15:16:42: Can't read key directory "\\PPLGR411\SYS\ADLM\KEY".
00-Apr-03 15:29:43: DRUMMLJ@160 [1], 150: SLID-1 1 issued, 1 in use.
00-Apr-03 15:32:19: DRUMMLJ@160 [2], 150: SLID-2 1 issued, 1 in use.
00-Apr-03 15:34:49: DRUMMLJ@160 [1]: Zombie.
00-Apr-03 15:34:49: DRUMMLJ@160 [1], 150: SLID-2 1 returned, 1 in use (used: 0:00:05:06).
Member
josborne
Re:
sys:adlm
adlm.log
*milana, jerry
Message 6 of 6 (98 Views)
Re:
04-03-2000 05:47 PM in reply to: josborne
John,
I do not think this configuration is going to work. If I understand you
correctly, you have three LAN connections on the AdLM server. AdLM is only
supported on systems with a single LAN connection.
Alternatives include using another server with only one connection or
running your network with TCP/IP and IPX Protocols and running the TCP/IP
version of AdLM on a Windows system which has a single network interface.
Jerry Milana,
news:eef6867.2@WebX.SaUCah8kaAW...
following directory
> sys:adlm
> adlm.log
(a178f84.000001).
(used: 0:02:13:44).
(used: 0:00:29:26).
(used: 0:00:03:58).
(used: 0:00:38:53).
(used: 0:03:24:45).
(used: 0:00:14:07).
(used: 0:00:05:06).
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
