Installation & Licensing
New Member
mattmlee
Message 1 of 4 (2,273 Views)
Failure to install True View 2013
2273 Views, 3 Replies
07-13-2012 10:39 AM
Got through the accepting terms/condtions part, the final installation started and quickly stopped.
I got a "Failed" marker and it said: "Installation complete.  Some products failed to install."
the instillation log file is attached
any help appreciated
TravisNave
Message 2 of 4 (2,234 Views)
Re: Failure to install True View 2013
07-16-2012 10:13 AM in reply to: mattmlee
Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
mattmlee
Message 3 of 4 (2,230 Views)
07-16-2012 11:19 AM in reply to: TravisNave
thanks a lot this appears to have worked
TravisNave
Message 4 of 4 (2,226 Views)
07-16-2012 11:24 AM in reply to: mattmlee
Excellent!  Thanks for the update.  :smileyhappy:
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
