Any ideas? Enclosed is the error shown at installation, and 3 install log files after failure to install.
Solved by alison.gangler. Go to Solution.
Can you check out this post?
From the Setup log you provided, the error is occurring in the Visual C++ 2008 x86 package. Generally, a good practice to quickly get to the cause of the issue is to enable the verbose logging for Windows Installer,
http://support.microsoft.com/kb/223300
Then launch the Visual C++ 2008 x86 package manually from the 3rdParty\x86\VCREDIST folder. You can then gather the windows installer log that will be generated in the TEMP directory, accessed by typing '%temp%' in the START > RUN. Feel free to attach that log (zipped or compressed please) and I can help you find out what is triggering the 1603 error.
Thank you,
Alison
