• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    luiww
    Failure message during installation
    208 Views, 6 Replies
    02-29-2012 05:27 PM
    I have the attached message while trying to install Inventor 2012.  I have Inventor 2011 in the system.  Do I need to remove 2011 in order to install 2012?
    Any advise on what is wrong with my installation?
    Please use plain text.
    New Member
    Re: Failure message during installation
    02-29-2012 08:31 PM in reply to: luiww
    I've had the same problem with Autodesk Revit MEP 2012 and one otther one, ive tried a few installs and redownloaded it, nothing worked, did  you get yours working?
    Active Member
    SubMerged
    03-01-2012 05:41 AM in reply to: luiww
    I was having the same problem and the fix I posted in reply to "Total installati​on failure consistent​ly"  posted by tc8224 worked for me and 2 others. I'm running Windows 7 64 bit so please take that into account.
    Search for the "Total installati​on failure consistent​ly"  post & see if that's what you're facing.
    TravisNave
    03-01-2012 10:43 AM in reply to: luiww
    The problem is detailed in your log file.
    It is failing on your C++ 2010 Redistributable.  Delete this program from your Control Panel > Programs and try to install again.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    03-01-2012 02:15 PM in reply to: luiww
    It may have to do with the 2012 versions because I went and tried the 2011 and all I tried worked
    TravisNave
    03-01-2012 02:17 PM in reply to: MATTHEW.GROSSKREUZ
    Yes, the 2012 versions typically are showing installation errors when the required prerequisites that are already installed are newer than the installer expects.  Generally uninstalling the prereq fixes this 99% of the time.
    Travis Nave
    luiww
    03-02-2012 04:24 AM in reply to: luiww
    Excellent and it works.  By removing the Microsoft C++ files as being told and re-installed the software.  Thanks.
