Installation & Licensing
Failure message during installation
6 REPLIES 6
luiww
468 Views, 6 Replies
I have the attached message while trying to install Inventor 2012.  I have Inventor 2011 in the system.  Do I need to remove 2011 in order to install 2012?
Any advise on what is wrong with my installation?
6 REPLIES 6
in reply to: luiww
I've had the same problem with Autodesk Revit MEP 2012 and one otther one, ive tried a few installs and redownloaded it, nothing worked, did  you get yours working?
in reply to: luiww
I was having the same problem and the fix I posted in reply to "Total installati​on failure consistent​ly"  posted by tc8224 worked for me and 2 others. I'm running Windows 7 64 bit so please take that into account.
Search for the "Total installati​on failure consistent​ly"  post & see if that's what you're facing.
TravisNave
in reply to: luiww
The problem is detailed in your log file.
It is failing on your C++ 2010 Redistributable.  Delete this program from your Control Panel > Programs and try to install again.
Autodesk Forums:
in reply to: luiww
It may have to do with the 2012 versions because I went and tried the 2011 and all I tried worked
TravisNave
Yes, the 2012 versions typically are showing installation errors when the required prerequisites that are already installed are newer than the installer expects.  Generally uninstalling the prereq fixes this 99% of the time.
Autodesk Forums:
luiww
in reply to: luiww
Excellent and it works.  By removing the Microsoft C++ files as being told and re-installed the software.  Thanks.
Administrator Productivity
