Installation & Licensing
Message 1 of 9
MMforCMC
300 Views, 8 Replies
Failing to install
We have recently gotten a new computer with windows 7 OS. My old computer sytem was windows xp and it was a 32bit system. I got from Autodesk "AutoCad_Mechanical_2012_English_Win_64bit.exe" and installed it. When I got to the finish Autocad failed to load and in the rror log it told me "You are attempting to use a 32-bit installer on a 64-bit operating system." What am I doing wrong.
Very frustrated.
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: MMforCMC
you can't install 32 bit mechanical 2012 on a 64 bit OS
You need to download the 64 bit 2012 mechanical
DarrenP
Message 3 of 9
MMforCMC
in reply to: DarrenP
I didn't. I downloaded and installed "Autocad_Mechanical_2012_English_Win_64bit.exe". It wasn't unil I got to the very end of the install that it failed to install. I have attached the error log that came once it failed to install.
Message 4 of 9
DarrenP
well thats wierd
its possible the download got corrupted in some way
might want to try to redownload the .exe again
DarrenP
Message 5 of 9
MMforCMC
Did that three times already.
Message 6 of 9
pendean
Message 7 of 9
MMforCMC
in reply to: pendean
Same as all my other attempts.
Message 8 of 9
pendean
From your log: "DirectX Runtime Failed Failure is ignored, Result=1619"
Search around here where you are posting for that problem and posted solutions.
Message 9 of 9
MMforCMC
Thanks for your help.
Don't worry about it, all is good. I had a tech come in and fix the problem. I am up and running now.
Administrator Productivity
