• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    JeffBowlin
    Failing 2012 Map 3D Instll
    395 Views, 3 Replies
    04-12-2012 08:26 AM
    Had to roll back .net at first, then the install progressed a little further. Not sure what I need to do if anyone can help.
    2012/4/12:08:40:38 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
    2012/4/12:08:40:38 jeffrey.bowlin C1F17L1 Launch
    2012/4/12:08:48:19 jeffrey.bowlin C1F17L1 === Setup ended ===
    2012/4/12:08:41:38 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
    2012/4/12:08:41:38 jeffrey.bowlin C1F17L1 Launch
    2012/4/12:08:46:23 jeffrey.bowlin C1F17L1 Installing .NET Framework Runtime 4.0: \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
    2012/4/12:08:51:35 jeffrey.bowlin C1F17L1 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
    2012/4/12:08:51:59 jeffrey.bowlin C1F17L1 === Setup ended ===
    2012/4/12:09:37:21 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
    2012/4/12:09:37:21 jeffrey.bowlin C1F17L1 Launch
    2012/4/12:09:42:59 jeffrey.bowlin C1F17L1 === Setup ended ===
    2012/4/12:09:38:04 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
    2012/4/12:09:38:04 jeffrey.bowlin C1F17L1 Launch
    2012/4/12:09:41:50 jeffrey.bowlin C1F17L1 Installing DirectX Runtime: \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent
    2012/4/12:09:47:05 jeffrey.bowlin C1F17L1 Install DirectX Runtime Succeeded
    2012/4/12:09:47:05 jeffrey.bowlin C1F17L1 Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/4/12:10:03:39 jeffrey.bowlin C1F17L1 Install FaroSDK Failed Failure is ignored, Result=1603
    2012/4/12:10:03:39 jeffrey.bowlin C1F17L1 Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/4/12:10:10:01 jeffrey.bowlin C1F17L1 Install Autodesk Material Library 2012 Succeeded
    2012/4/12:10:10:01 jeffrey.bowlin C1F17L1 Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/4/12:10:15:02 jeffrey.bowlin C1F17L1 Install Autodesk Material Library 2012 - Low Resolution Succeeded
    2012/4/12:10:15:02 jeffrey.bowlin C1F17L1 Installing Microsoft Visual C++ 2005 Redistributable (x86): \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JEFFRE~1.BOW\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/4/12:10:30:31 jeffrey.bowlin C1F17L1 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
    2012/4/12:10:30:45 jeffrey.bowlin C1F17L1 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
    2012/4/12:10:31:04 jeffrey.bowlin C1F17L1 Rollback Autodesk Material Library 2012 Succeeded
    2012/4/12:10:31:04 jeffrey.bowlin C1F17L1 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2012/4/12:10:31:22 jeffrey.bowlin C1F17L1 === Setup ended ===
    Please use plain text.
    TravisNave
    Re: Failing 2012 Map 3D Instll
    04-12-2012 05:22 PM in reply to: JeffBowlin
    Install ​Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    JeffBowlin
    04-18-2012 06:22 AM in reply to: JeffBowlin
    Product installed after machine was reimaged. After installation, app opened, all menus present.
    End user however has no menus, and has some isse saving profile....
    ugh
    TravisNave
    04-18-2012 07:56 AM in reply to: JeffBowlin
    Make sure the end user has local administrator rights and that the My Documents folder is not being redirected.
    Travis Nave
