Installation & Licensing
mlg
Member
mlg
Message 1 of 6 (3,591 Views)
Failed to find node error when installing C3D 2012
3591 Views, 5 Replies
06-17-2011 04:53 AM
Each time I attempt to install C3D 2012, after the insatll nearly finishing I get an error window stating "Failed to find node" and long message along with it.  I'm running WIN7, 64 bit, and I've never had any trouble installing any previous versions.
 Any ideas?  I've included the error window.
Product Support
david.lau
Message 2 of 6 (3,582 Views)
Re: Failed to find node error when installing C3D 2012
06-21-2011 01:51 PM in reply to: mlg
Can you try to uinstall the Autodesk Content Service from the control panel?
David Lau
mlg
Member
mlg
Message 3 of 6 (3,571 Views)
06-23-2011 08:06 AM in reply to: david.lau
Thanks David!  That took care of it.  I guess I didn't get all the beta goodies removed before trying to install the real thing.
New Member
john.holding
Message 4 of 6 (3,060 Views)
08-30-2012 04:42 AM in reply to: mlg
Hi  I am having the same problem
I am trying to install ACA 2012 but I already have installed ACA2013, the only content  service I can see is for 2013,
if i delete it what will happen to ACA 2013?
can you please help?
Thanks in advance for any help you may be able to give
Mike42
Message 5 of 6 (1,356 Views)
10-10-2013 11:24 AM in reply to: mlg
Having the same issue reinstalling 2012 C3D with a copy of 2014 already installed. Does delting the content service mess up my 2014 install?
Product Support
asburyj
Message 6 of 6 (1,352 Views)
10-10-2013 11:56 AM in reply to: Mike42
It is always recommended to install your products oldest to newest because there are some shared components, like the content service, that will be upgraded. When the older products install is trying to install it's own content service it will run into errors because a newer version is already there if you have installed a newer version first. The best practice is to install everything oldest to newest.
Jeffry Asbury
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
