Installation & Licensing
Failed to acquite a license
2 REPLIES 2
younghwi
755 Views, 2 Replies
This is message when i perform status enquiry.
Does anyone know about this problem? i can not activate vault collaboration with this matter.
License server status: @SECOND0261F9P     License file(s) on SECOND0261F9P: C:\Program Files\Autodesk Network License Manager\License\license.lic:
lmgrd is not running: License server machine is down or not responding.  See the system adminstrator about starting the license server system, or  make sure you're referring to the right host (see LM_LICENSE_FILE). Hostname:      SECOND0261F9P License path:  @SECOND0261F9P; FLEXnet Licensing error:-96,7.  System Error: 11001 "Comm. error" For further information, refer to the FLEXnet Licensing documentation, available at "www.flexerasoftware.com".
2 REPLIES 2
aaronhai
in reply to: younghwi
Hi younghwi,
Please see if this Technical Solution helps.
Thank you.
Aaron Hai
TravisNave
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Autodesk Forums:
Administrator Productivity
