i am facing problem while installing AutoCAD 2013 on my win 8 tablet..i am getting error 193.. i ve checked internet about this error and try some modifications but couldnt solve it.. i deleted all windows visual c++ 2005 and 2008 versions and also 2010 (x86)... kept only 2010 (x64)... please check my log file...looking forward your help, thanks in advance
2013/10/27:21:33:56 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:33:56 ahmet naim AHMETNAIM Launch
2013/10/27:21:33:59 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:33:57 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:33:57 ahmet naim AHMETNAIM Launch
2013/10/27:21:33:59 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:34:04 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:34:06 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:35:34 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:35:47 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:35:47 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:35:47 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:35:48 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:36:01 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:37:02 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:37:02 ahmet naim AHMETNAIM Launch
2013/10/27:21:37:06 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:37:03 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:37:03 ahmet naim AHMETNAIM Launch
2013/10/27:21:37:06 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:14 ahmet naim AHMETNAIM PageOpen BeginDeploymentDialog
2013/10/27:21:37:18 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:23 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:37:23 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:37:27 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:37:27 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:32 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:38:03 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:38:03 ahmet naim AHMETNAIM Launch
2013/10/27:21:38:06 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:38:04 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:38:04 ahmet naim AHMETNAIM Launch
2013/10/27:21:38:06 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:38:07 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:38:11 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:38:53 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:39:06 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:39:06 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:39:06 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:40:40 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:40:40 ahmet naim AHMETNAIM Launch
2013/10/27:21:40:40 ahmet naim AHMETNAIM An instance of setup is already running. Only one instance of setup can run at a time.2013/10/27:21:40:42 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:39:07 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:40:44 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:44:44 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:44:44 ahmet naim AHMETNAIM Launch
2013/10/27:21:44:47 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:44:45 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:44:45 ahmet naim AHMETNAIM Launch
2013/10/27:21:44:46 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:44:50 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:44:53 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:46:54 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:46:57 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:46:57 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:46:57 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:46:57 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:52:08 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:52:23 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:52:23 ahmet naim AHMETNAIM Launch
2013/10/27:21:52:27 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:52:24 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:52:24 ahmet naim AHMETNAIM Launch
2013/10/27:21:52:26 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:54:38 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:59:11 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:59:11 ahmet naim AHMETNAIM Launch
2013/10/27:21:59:14 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:59:12 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:59:12 ahmet naim AHMETNAIM Launch
2013/10/27:21:59:14 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:59:21 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:59:26 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:59:52 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:59:54 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:59:54 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:59:54 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:59:54 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:00:00 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:01:44 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:01:44 ahmet naim AHMETNAIM Launch
2013/10/27:22:01:46 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:01:45 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:01:45 ahmet naim AHMETNAIM Launch
2013/10/27:22:01:46 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:01:47 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:01:50 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:02:21 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:02:23 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:02:23 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:02:23 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:02:23 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:05:17 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:05:21 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:05:21 ahmet naim AHMETNAIM Launch
2013/10/27:22:05:24 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:05:22 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:05:22 ahmet naim AHMETNAIM Launch
2013/10/27:22:05:24 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:05:26 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:05:29 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:06:02 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:06:04 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:06:04 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:06:04 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:06:04 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:06:13 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:07:37 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:07:37 ahmet naim AHMETNAIM Launch
2013/10/27:22:07:39 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:07:38 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:07:38 ahmet naim AHMETNAIM Launch
2013/10/27:22:07:39 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:07:41 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:07:44 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:08:00 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:08:06 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:08:06 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:08:06 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:08:06 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:13:15 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:18:13 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:18:13 ahmet naim AHMETNAIM Launch
2013/10/27:22:18:15 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:18:14 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:18:14 ahmet naim AHMETNAIM Launch
2013/10/27:22:18:15 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:19:01 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:19:04 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:19:30 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:19:33 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:19:33 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:19:33 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:19:34 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:28:21 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:33:51 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:33:51 ahmet naim AHMETNAIM Launch
2013/10/27:22:33:53 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:33:52 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:33:52 ahmet naim AHMETNAIM Launch
2013/10/27:22:33:53 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:33:54 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:33:58 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:34:18 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:34:20 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:34:20 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:34:20 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:34:20 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:36:08 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:43:32 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:43:32 ahmet naim AHMETNAIM Launch
2013/10/27:22:43:34 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:43:34 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:43:35 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:43:37 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:44:16 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:44:18 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:44:18 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:44:18 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
Please check your TEMP folder for a clue on why the C++ component didn't install. A sample log is below:
You can try the following:
Also, you can unninstall the 2010 C++ components via the Control Panel and try the installation of the software again.
Hello David,
I tried the things in your link but i am still getting the same result. Also i deleted all the C++ versions..and tried again..
i couldnt find any log file in my temp folder besides..Can you please guide me to find the installation guide that you attached in your post?
the things that i couldn't get;
1-which version of C++ should we install ? 2005, 2008, 2010, 2013?
2-i am using windows 8 x64..why this installation is interested with x86 of VCRedist although there is x64 folder in 3rdParty folder ?
i opened x64 setup manually and installed then opened the software installation but it didnt work as well.
Hello. Did you uninstall all the C++ on your machine or just 2010? I would uninstall all eth 2005, 2008, and 2010 entries. Your log file explicitly states you are having an issue with a 2008 version. If you uninstalled a different year, you could be uninstalling around the problem. Just wanted to make sure you tried removing all the C++.
Thank you for taking part in our community!
