Installation & Licensing
Failed - Fatal error during installation.
13 REPLIES 13
Message 1 of 14
6218 Views, 13 Replies
Anyone can help please? Badly needed.
13 REPLIES 13
Message 2 of 14
TravisNave
Please attach the log file listed in that error.  It will have the reason for the failure.
Autodesk Forums:
Message 3 of 14
is this the log ? I've tried so many times installing this AutoCAD 2011 32bit.
BTW my processor
AMD Athlon(tm) II X2 240 Processor ~2.8GHz
3GB RAM
256 Video Card
Windows XP
Message 4 of 14
TravisNave
Yeah, but it doesn't really help.  There might be a bigger log file in yoru %TEMP% folder as well related to this one.
Also, are you installing from media, download, or what?
Autodesk Forums:
Message 5 of 14
Yeah, i see a lot of .NET Framework, should i delete all files in my %TEMP% folder ? I'd just copy this AutoCAD to my buddy. Then what should I do now? 😞
Message 6 of 14
TravisNave
Yeah, it's a good idea to clear all the files in your %TEMP% folder first.  If the installation files are downloaded onto your hard drive, that's preferred.  Make sure you have local admin rights on your machine and that your anti-virus is temporarily disabled during the install.  Give it another go.  If it fails, it should be easier to locate the necessary log files.
Autodesk Forums:
Message 7 of 14
I've seen another log file AutoCAD 2011 Install.log about 3.14MB , so ill delete all files here in my %TEMP% and then run again the Autodesk.exe ? Do you mean "run as admin" ?
Message 8 of 14
TravisNave
You could do a Run As Administrator if you have that account enabled in XP.  However, so long as your user account has local admin rights, you are fine.  Alternately, you can also try creating another local user with admin rights and logging it as that account and trying again.  Sometimes Windows profile issues can cause weird problems.  And a fresh profile often times resolves that.
Autodesk Forums:
Message 9 of 14
Hey buddy, still error.
Theses are the files added to my %TEMP% folder
AcDeltree.exe
AutoCAD 2011 Setup.log
Message 10 of 14
in reply to: TravisNave
These are the 3 file that i couldnt install, when installing AutoCAD 2011 i got error saying "Failed - Fatal error during installation." 😞
Message 11 of 14
TravisNave
Zip and attach the log file.  Perhaps somebody at Autodesk will be able to look at it.
Autodesk Forums:
Message 12 of 14
These are the log files seen on my %TEMP% folder.
Message 13 of 14
petromligo24
have the problem during installation Autocad civil 3D 2011 in my Laptop,failed  -Fatar error during installation .computer properties are:-
window 7 professional,processor Intel(R) core (TM) 2Duo CPU  p8600 @ 2.40GHZ  2.40GHZ
RAM 2.00GB
System type 32-bit
So how to solve this problem
Message 14 of 14
Darin.Green
in reply to: petromligo24
@petromligo24
Given that this is a 5 year old post... For starters, create a new post and provide your installation log file found in your %temp% directory.
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
