• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Failed - AutoCAD 2012 Building Design Suite
    162 Views, 5 Replies
    01-22-2013 02:28 PM
    OK, I have installed AutoCAD 2012 on my desktop and now I am installing it on a laptop for out of office use at home.  I thought since I had the new 2013 I could just install it and I did.  It failed.  I uninstalled it completely using the steps found on this web site.  Started over this time using the 2012 version.  It failed.  I tried uninstalling and reinstalling at least four more times with the same results, FAILED!  I am now frustrated beyond sanity.  I need this to work but haverun out of ideas.  I know I'm doing something wrong but I can't put my finger on what it is.  I need help.
    I am running 64bit Windows 7, 2gig video, 16gig RAM, Core i7 2.7 processor, 750 gig hard drive.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Failed - AutoCAD 2012 Building Design Suite
    01-22-2013 02:39 PM in reply to: rrr2263
    Post the install log linked in the failure summary page.  It's most like a prerequisite failure.
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    01-23-2013 06:30 AM in reply to: TravisNave
    Here it is.
    *Expert Elite*
    DarrenP
    01-23-2013 06:41 AM in reply to: rrr2263
    its the 1603 error
    read through the link travis posted on what to do
    Active Member
    01-23-2013 06:51 AM in reply to: DarrenP
    *Expert Elite*
    TravisNave
    01-23-2013 07:39 AM in reply to: rrr2263
    Yeah Darren called it.  Specifically, this is what is failing:
    Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
    So like he said, click that link and start with that program.  Then try again.  Let us know.
    Travis Nave
