Installation & Licensing
New Member
greg_galicia
Message 1 of 3 (2,638 Views)
Fail in installing AutoCad 2012 (downloaded from AutoDesk page)
2638 Views, 2 Replies
09-26-2011 05:22 PM
2011/9/26:16:43:56    greg    GREG-PC    === Setup started on GREG-PC by greg ===
2011/9/26:16:43:56    greg    GREG-PC    Launch
2011/9/26:16:44:06    greg    GREG-PC    === Setup ended ===
2011/9/26:16:44:06    greg    GREG-PC    PageOpen    LaunchDialog
2011/9/26:16:44:36    greg    GREG-PC    PageOpen    LicenseDialog
2011/9/26:16:45:19    greg    GREG-PC    PageOpen    ProductInfoDialog
2011/9/26:16:46:11    greg    GREG-PC    PageOpen    ProductSelectionDialog2
2011/9/26:16:46:19    greg    GREG-PC    PageOpen    FullProgressDialog
2011/9/26:16:46:19    greg    GREG-PC    Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/26:16:46:54    greg    GREG-PC    Install    DirectX Runtime    Succeeded
2011/9/26:16:46:54    greg    GREG-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:16:47:01    greg    GREG-PC    Install    FaroSDK    Succeeded
2011/9/26:16:47:01    greg    GREG-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:16:47:09    greg    GREG-PC    Install    Autodesk Material Library 2012    Succeeded
2011/9/26:16:47:09    greg    GREG-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:16:47:23    greg    GREG-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2011/9/26:16:47:23    greg    GREG-PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:16:47:29    greg    GREG-PC    Install    Autodesk Content Service    Succeeded
2011/9/26:16:47:29    greg    GREG-PC    Installing AutoCAD® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\greg\AppData\Local\Temp\_AI8FF0.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:16:47:37    greg    GREG-PC    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
2011/9/26:16:47:43    greg    GREG-PC    Rollback    Autodesk Content Service    Succeeded
2011/9/26:16:47:53    greg    GREG-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2011/9/26:16:48:07    greg    GREG-PC    Rollback    Autodesk Material Library 2012    Succeeded
2011/9/26:16:48:08    greg    GREG-PC    Rollback    FaroSDK    Succeeded
2011/9/26:16:48:08    greg    GREG-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2011/9/26:16:48:08    greg    GREG-PC    PageOpen    InstallCompleteDialog
2011/9/26:17:01:30    greg    GREG-PC    === Setup ended ===
2011/9/26:17:07:15    greg    GREG-PC    === Setup started on GREG-PC by greg ===
2011/9/26:17:07:15    greg    GREG-PC    Launch
2011/9/26:17:07:19    greg    GREG-PC    === Setup ended ===
2011/9/26:17:07:19    greg    GREG-PC    PageOpen    LaunchDialog
2011/9/26:17:08:13    greg    GREG-PC    PageOpen    LicenseDialog
2011/9/26:17:11:22    greg    GREG-PC    PageOpen    ProductInfoDialog
2011/9/26:17:11:43    greg    GREG-PC    PageOpen    ProductSelectionDialog2
2011/9/26:17:13:39    greg    GREG-PC    PageOpen    FullProgressDialog
2011/9/26:17:13:39    greg    GREG-PC    Installing Autodesk® Design Review:  TRANSFORMS="C:\Users\greg\AppData\Local\Temp\_AIE8E8.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:14:00    greg    GREG-PC    Install    Autodesk® Design Review    Succeeded
2011/9/26:17:14:00    greg    GREG-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2011/9/26:17:14:25    greg    GREG-PC    Install    DirectX Runtime    Succeeded
2011/9/26:17:14:25    greg    GREG-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:14:31    greg    GREG-PC    Install    FaroSDK    Succeeded
2011/9/26:17:14:31    greg    GREG-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:14:40    greg    GREG-PC    Install    Autodesk Material Library 2012    Succeeded
2011/9/26:17:14:40    greg    GREG-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:14:54    greg    GREG-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2011/9/26:17:14:54    greg    GREG-PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:14:59    greg    GREG-PC    Install    Autodesk Content Service    Succeeded
2011/9/26:17:15:00    greg    GREG-PC    Installing AutoCAD® 2012:  TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\greg\AppData\Local\Temp\_AIE8E8.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/9/26:17:15:30    greg    GREG-PC    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
2011/9/26:17:15:33    greg    GREG-PC    Rollback    Autodesk Content Service    Succeeded
2011/9/26:17:15:45    greg    GREG-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2011/9/26:17:15:58    greg    GREG-PC    Rollback    Autodesk Material Library 2012    Succeeded
2011/9/26:17:15:59    greg    GREG-PC    Rollback    FaroSDK    Succeeded
2011/9/26:17:15:59    greg    GREG-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2011/9/26:17:16:06    greg    GREG-PC    Rollback    Autodesk® Design Review    Succeeded
I have uninstalled and install the software but nothing seems to be working. If I click directly, the autocad icon, it gives me this error: "adui18res.dll cannot be found".
By the way, this is the student version. I am running on Win 7.
Valued Mentor
bgingerich
Message 2 of 3 (2,613 Views)
Re: Fail in installing AutoCad 2012 (downloaded from AutoDesk page)
09-27-2011 06:26 AM in reply to: greg_galicia
When I installed 2012 it gave me that error too.
I when to http://www.microsoft.com/download/en/details.aspx?id=35 and downloaded and installed it first.  Then I could install 2012 just fine.
Not sure why it worked
HTH
Brandon Gingerich
New Member
greg_galicia
Message 3 of 3 (2,599 Views)
09-27-2011 12:24 PM in reply to: greg_galicia
Tried it but the error is still there. It is looking for ADUI18RES.DLL and Directx.
If I click on the Autocad icon on the program file, this error props up -adui18res.dll.
If i install autocad and go through the process up to the installation page, it will say Directx not found or something to that effect. Frustrating!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
