• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    greg_galicia
    Fail in installing AutoCad 2012 (downloaded from AutoDesk page)
    2257 Views, 2 Replies
    09-26-2011 05:22 PM
    2011/9/26:16:43:56    greg    GREG-PC    === Setup started on GREG-PC by greg ===
    2011/9/26:16:43:56    greg    GREG-PC    Launch
    2011/9/26:16:44:06    greg    GREG-PC    === Setup ended ===
    2011/9/26:16:44:06    greg    GREG-PC    PageOpen    LaunchDialog
    2011/9/26:16:44:36    greg    GREG-PC    PageOpen    LicenseDialog
    2011/9/26:16:45:19    greg    GREG-PC    PageOpen    ProductInfoDialog
    2011/9/26:16:46:11    greg    GREG-PC    PageOpen    ProductSelectionDialog2
    2011/9/26:16:46:19    greg    GREG-PC    PageOpen    FullProgressDialog
    2011/9/26:16:46:19    greg    GREG-PC    Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2011/9/26:16:46:54    greg    GREG-PC    Install    DirectX Runtime    Succeeded
    2011/9/26:16:46:54    greg    GREG-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:16:47:01    greg    GREG-PC    Install    FaroSDK    Succeeded
    2011/9/26:16:47:01    greg    GREG-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:16:47:09    greg    GREG-PC    Install    Autodesk Material Library 2012    Succeeded
    2011/9/26:16:47:09    greg    GREG-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:16:47:23    greg    GREG-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
    2011/9/26:16:47:23    greg    GREG-PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:16:47:29    greg    GREG-PC    Install    Autodesk Content Service    Succeeded
    2011/9/26:16:47:29    greg    GREG-PC    Installing AutoCAD® 2012:  TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\greg\AppData\Local\Temp\_AI8FF0.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:16:47:37    greg    GREG-PC    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
    2011/9/26:16:47:43    greg    GREG-PC    Rollback    Autodesk Content Service    Succeeded
    2011/9/26:16:47:53    greg    GREG-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
    2011/9/26:16:48:07    greg    GREG-PC    Rollback    Autodesk Material Library 2012    Succeeded
    2011/9/26:16:48:08    greg    GREG-PC    Rollback    FaroSDK    Succeeded
    2011/9/26:16:48:08    greg    GREG-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
    2011/9/26:16:48:08    greg    GREG-PC    PageOpen    InstallCompleteDialog
    2011/9/26:17:01:30    greg    GREG-PC    === Setup ended ===
    2011/9/26:17:07:15    greg    GREG-PC    === Setup started on GREG-PC by greg ===
    2011/9/26:17:07:15    greg    GREG-PC    Launch
    2011/9/26:17:07:19    greg    GREG-PC    === Setup ended ===
    2011/9/26:17:07:19    greg    GREG-PC    PageOpen    LaunchDialog
    2011/9/26:17:08:13    greg    GREG-PC    PageOpen    LicenseDialog
    2011/9/26:17:11:22    greg    GREG-PC    PageOpen    ProductInfoDialog
    2011/9/26:17:11:43    greg    GREG-PC    PageOpen    ProductSelectionDialog2
    2011/9/26:17:13:39    greg    GREG-PC    PageOpen    FullProgressDialog
    2011/9/26:17:13:39    greg    GREG-PC    Installing Autodesk® Design Review:  TRANSFORMS="C:\Users\greg\AppData\Local\Temp\_AIE8E8.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:14:00    greg    GREG-PC    Install    Autodesk® Design Review    Succeeded
    2011/9/26:17:14:00    greg    GREG-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
    2011/9/26:17:14:25    greg    GREG-PC    Install    DirectX Runtime    Succeeded
    2011/9/26:17:14:25    greg    GREG-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:14:31    greg    GREG-PC    Install    FaroSDK    Succeeded
    2011/9/26:17:14:31    greg    GREG-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:14:40    greg    GREG-PC    Install    Autodesk Material Library 2012    Succeeded
    2011/9/26:17:14:40    greg    GREG-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:14:54    greg    GREG-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
    2011/9/26:17:14:54    greg    GREG-PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:14:59    greg    GREG-PC    Install    Autodesk Content Service    Succeeded
    2011/9/26:17:15:00    greg    GREG-PC    Installing AutoCAD® 2012:  TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\greg\AppData\Local\Temp\_AIE8E8.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2011/9/26:17:15:30    greg    GREG-PC    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
    2011/9/26:17:15:33    greg    GREG-PC    Rollback    Autodesk Content Service    Succeeded
    2011/9/26:17:15:45    greg    GREG-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
    2011/9/26:17:15:58    greg    GREG-PC    Rollback    Autodesk Material Library 2012    Succeeded
    2011/9/26:17:15:59    greg    GREG-PC    Rollback    FaroSDK    Succeeded
    2011/9/26:17:15:59    greg    GREG-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
    2011/9/26:17:16:06    greg    GREG-PC    Rollback    Autodesk® Design Review    Succeeded
    I have uninstalled and install the software but nothing seems to be working. If I click directly, the autocad icon, it gives me this error: "adui18res.dll cannot be found".
    By the way, this is the student version. I am running on Win 7.
    Please use plain text.
    bgingerich
    Re: Fail in installing AutoCad 2012 (downloaded from AutoDesk page)
    09-27-2011 06:26 AM in reply to: greg_galicia
    When I installed 2012 it gave me that error too.
    I when to http://www.microsoft.com/download/en/details.aspx?id=35 and downloaded and installed it first.  Then I could install 2012 just fine.
    Not sure why it worked
    HTH
    Brandon Gingerich
    New Member
    greg_galicia
    09-27-2011 12:24 PM in reply to: greg_galicia
    Tried it but the error is still there. It is looking for ADUI18RES.DLL and Directx.
    If I click on the Autocad icon on the program file, this error props up -adui18res.dll.
    If i install autocad and go through the process up to the installation page, it will say Directx not found or something to that effect. Frustrating!
