Hello all,
We are receiving licens errors on our server. The only thing that I know of that has changed is this server to get migrated over to VM. I double checked the mac on the server and it does match what is in lmtools. Any ideas?
Flexible License Manager status on Mon 9/24/2012 11:53
[Detecting lmgrd processes...]
License server status: 27000@wchs-fs4
License file(s) on wchs-fs4: C:\Program Files\Autodesk Network License Manager\License\DES_ACA2012licenseCombined 2013.lic:
wchs-fs4: license server UP (MASTER) v11.10
Vendor daemon status (on wchs-fs4):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: wchs-fs4
License path: 27000@wchs-fs4;
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
does the license file have the correct MAC address?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13587543&linkID=12544120
DarrenP
I did look at that prior to posting and yes it does...
Do you think I have to re create the deployment? Im not sure if that might just be easier anyway...
did the host name change?
DarrenP
yea you could change the VM to match the license file or just generate a new license file using the hostname of the VM
DarrenP
