Installation & Licensing
FLEXnet Licensing error:-97,121
7 REPLIES 7
Message 1 of 8
rehlers
1643 Views, 7 Replies
Hello all,
We are receiving licens errors on our server. The only thing that I know of that has changed is this server to get migrated over to VM.   I double checked the mac on the server and it does match what is in lmtools.  Any ideas?
Flexible License Manager status on Mon 9/24/2012 11:53
[Detecting lmgrd processes...]
License server status: 27000@wchs-fs4
License file(s) on wchs-fs4: C:\Program Files\Autodesk Network License Manager\License\DES_ACA2012licenseCombined 2013.lic:
wchs-fs4: license server UP (MASTER) v11.10
Vendor daemon status (on wchs-fs4):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: wchs-fs4
License path: 27000@wchs-fs4;
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: rehlers
does the license file have the correct MAC address?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13587543&linkID=12544120
DarrenP
Message 3 of 8
rehlers
in reply to: DarrenP
I did look at that prior to posting and yes it does...
Do you think I have to re create the deployment?  Im not sure if that might just be easier anyway...
Message 4 of 8
DarrenP
did the host name change?
DarrenP
Message 5 of 8
rehlers
Yes it did...Now I am assuming I should change that.
Message 6 of 8
DarrenP
yea you could change the VM to match the license file or just generate a new license file using the hostname of the VM
DarrenP
Message 7 of 8
rehlers
I was just assuming it would follow its dns name.
Host: wchs-vm1.wchs.dist
Message 8 of 8
rehlers
I will try that..thanks a bunch.
Administrator Productivity
