• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Distinguished Contributor
    jeromecastaneda
    Accepted Solution
    FLEXnet Licensing error:-97,121
    13714 Views, 11 Replies
    03-12-2012 08:56 PM
    Flexible License Manager status on Tue 3/13/2012 11:05
    [Detecting lmgrd processes...]
    License server status: 27000@Crown-Server
    License file(s) on Crown-Server: C:\Program Files\Autodesk\Autodesk Network License Manager\License\CrownSys_Combined.lic:
    Crown-Server: license server UP (MASTER) v11.9
    We have problem connecting to the license server.
    Here's from the Perform Status Enquiry
    Vendor daemon status (on Crown-Server):
    adskflex: The desired vendor daemon is down.
    Check the lmgrd log file, or try lmreread.
    Vendor:Host: Crown-Server
    License path: 27000@Crown-Server;
    Things that were done:
    1. Firewalls are all disabled
    2. created an exception rule (inbound and outbound) to port 2080
    3. created ADSKFLEX_LICENSE_FILE in the system variable with value @203.92.109.98
    4. reinstalled LMtools and created new Service to re Configure Service
    Attached is the debug log for more reference. here were the last status
    10:49:12 (adskflex) Vendor daemon can't talk to lmgrd (License server machine is down or not responding. (-96,491))
    10:49:12 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
    10:49:16 (lmgrd) adskflex exited with status 28 (Communications error)
    10:49:16 (lmgrd) Please correct problem and restart daemons
    thanks a lot,
    Jerome
    http://engr.jeromecastaneda.com/
    “What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” - Albert Pine
    Please use plain text.
    Active Member
    Re: FLEXnet Licensing error:-97,121
    03-13-2012 01:53 PM in reply to: jeromecastaneda
    Try to disable any Antivirus software running on your FLEXlm license server machine. Sometimes it blocks the vendor daemon.
    Oren Gabay
    OpenLM - Streching your licenses to their limit
    http://www.openlm.com
    jeromecastaneda
    03-13-2012 06:23 PM in reply to: orengabay
    Hello Oren,
    The antivirus is not running in the background.
    Any other thoughts?
    thanks,
    Jerome
    New Member
    03-14-2012 03:37 AM in reply to: jeromecastaneda
    Hi Jerome,
    Have you managed to fix this as we are having the same problem.  Except in our case we installed the licence manager on a new server after retiring the old one, generated a new licence file with the details in and the just get that exact same error.  We have no antivirus installed on this particular server as it's only other role is as a DC and AutoCAD support have checked the licence file which is not the problem, unfortunately that's the limit of the support they are willing to give us.
    We are using the 2009 suite of autocad products (Revit, Inventor and 3ds Max)
    Regards
    Jamie Kelly
    Network Technician
    Boston College, Lincolnshire, UK
    Active Member
    03-14-2012 03:53 AM in reply to: jeromecastaneda
    Hi Jerome,
    I further investigated this and found that it may be related with DNS issues on the license server machine.
    Check your server hostname name by the "hostname" command and then try to ping this name on the license server, it should work. You can also try to use the FQDN in the license file.
    Another option to check is described in IBM Rational support page - http://www-01.ibm.com/support/docview.wss?uid=swg21296320. Probably it's related to old versions of FLEXlm but worth checking.
    Sincerely,
    Oren
    Oren Gabay
    jeromecastaneda
    03-14-2012 07:07 PM in reply to: orengabay
    Hi Oren,
    We can ping the server however still got the same problem.
    Flexible License Manager status on Thu 3/15/2012 09:58
    Error getting status: Cannot connect to license server system.
    The license server manager (lmgrd) has not been started yet,
    the wrong port@host or license file is being used, or the
    port or hostname in the license file has been changed.
    Server name: 203.92.109.98
    License path: @203.92.109.98;
    FLEXnet Licensing error:-15,570
    For further information, refer to the FLEXnet Licensing documentation,
    Pls. advise more about FDQN in license file. how do you do that?
    We're using Flexera version v11.9.0.0 build 87342 x64_n6
    Jerome
    jeromecastaneda
    03-14-2012 08:29 PM in reply to: jamiekelly9059
    Hi Jamie,
    I went through your log file and found these last lines
    10:25:13 (lmgrd) adskflex exited with status 27 (No features to serve)
    10:25:13 (lmgrd) adskflex daemon found no features. Please correct
    10:25:13 (lmgrd) license file and re-start daemons.
    10:25:13 (lmgrd)
    10:25:13 (lmgrd) This may be due to the fact that you are using
    10:25:13 (lmgrd) a different license file from the one you expect.
    10:25:13 (lmgrd) Check to make sure that:
    10:25:13 (lmgrd) C:\Users\veritas\Desktop\CAD Licence File\Muffin.lic
    10:25:13 (lmgrd) is the license file you want to use.
    10:25:13 (lmgrd)
    Have you done this?
    Jerome
    Active Member
    03-15-2012 01:35 AM in reply to: jeromecastaneda
    Hi Jerome,
    Can you post the header of the license file in order to check the definitions in the server & vendor lines?
    SIncerely,
    Oren
    jeromecastaneda
    03-15-2012 02:55 AM in reply to: orengabay
    Hi Oren,
    Appreciate your help.
    We were able to resolve this issue.
    In the LMTools first tab and Configuration using Services selected, we enabled LMTOOLS ignores license file path environment variables. Yes that did the trick with the tick. :smileyhappy:
    Jerome
    Active Member
    03-15-2012 03:13 AM in reply to: jeromecastaneda
    Hi Jerome,
    I am happy to hear that I was able to help.
    Sincerely,
    Oren
