Installation & Licensing
FLEXnet Licensing error:-125,147
8 REPLIES 8
Message 1 of 9
david.lau
4802 Views, 8 Replies
When using an network version of an Autodesk product,  you may see this error:  FLEXnet Licensing error:-125,147.
  1. This error can be safely ignored!
  2. This message is generated by going into the Lmtools Utility > Server Diags tab > Perform Diagnostics button.
  3. Basically, the core funtionality of licensing is provided by Flexera.  Autodesk has customized the licensing scheme by using a PACKAGE line in the license file.   The Server Diag tab only knows core Flexera functionality (i.e. FEATURE, INCREMENT) and therefore will error out with these PACKAGE lines.
  4.  You will be able to view the contents of your Network license file using this website: www.licenseparser.com.
Some additional posts that refer to this topic are below:
David Lau
8 REPLIES 8
Message 2 of 9
in reply to: david.lau
I have this error. I bought a network subscription a month ago for 1 seat. I then bought another network seat yesterday. I added the INCREMENT part to the .lic file and restarted the LMTools server. I am not able to have 2 users in AutoCAD 2016 at the same time, it keeps telling me i have run out of seats althought I now have 2 purchased.
Message 3 of 9
DarrenP
both license files need to be generated on the same day and combined
thats why flex lm is only seeing 1 license
DarrenP
Message 4 of 9
in reply to: DarrenP
Thanks! How can i confirm that LMtools is reading the .lic file correctly and providing me with 2 available seats?
Message 5 of 9
DarrenP
run a status enquiry on flex LM
by going to the server status tab in Flex LM
DarrenP
Message 6 of 9
Thanks. I did that and I only see a qty of 1 on several lines items. Should it say qty of 2, or since I have separate license numbers that it will only say qty of 1 but it will be listed twice?
Message 7 of 9
DarrenP
its going to say to 1 since it only reads the latest license generated it ignores anything else
you will need to regenerate both license files the same day so Flex LM will see 2 instead of 1
DarrenP
Message 8 of 9
Darren,
Thanks for sticking with me. I went in an regerneated both licenses today. I generated the first license and saved that .lic file to my desktop. I generated the second one (as I didn't see a way to place 2 serial numbers in one gernation), saved that .lic file to my desktop. I then copied the Incrament part from lic 2 into lic one and saved it as combined.lic
I then placed that file on my server and told LMTools to re-read the license file. I also stopped and started the licenses manager.
What am I missing?
Message 9 of 9
DarrenP
you need to copy the package and Increment
read this guide
http://forums.autodesk.com/t5/installation-licensing/combining-license-files-for-subscription-and-no...
DarrenP
Administrator Productivity
