Installation & Licensing
FLEXnet License Finder Error
8 REPLIES 8
Message 1 of 9
SteveKS
17862 Views, 8 Replies
I'm having an autodesk inventor 10 network key error that others seem to have had ("Your application was not able to obtain a license because the FLEXnet license serve manager could not determine where to find the licensing data....").  I've tried the timeout extension fix, without success.  I believe my license is properly working, as a status inquiry returns the 1 license issued; total of 0 in use message.
Any help would be appreciated.
Steve
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: SteveKS
Make sure you can ping the server by name and that you get the correct IP address response.
You should also consider making a system environment variable named ADSKFLEX_LICENSE_FILE with the value of @SERVERNAME in addition to the FLEXLM_TIMEOUT value of 1000000.
What error number are you getting?
Autodesk Forums:
Message 3 of 9
SteveKS
It has been fixed by a support person.  I'm not quite sure what they did, but it had something to do with DNS and the server name not being recognized.  Thanks for the help, anyway.
Message 4 of 9
TravisNave
That would do it.  Testing it with a ping to machine name validates that.  Glad you are up and running.
Autodesk Forums:
Message 5 of 9
Enter the ip instead of hostname.
Message 6 of 9
"Enter the ip instead of hostname."
saved my life, dude - thanks.
Message 7 of 9
I tried entering the Ip. it didn't work. Gives me error 15.570. If I have a license file I have no idea where it is. I'm a student and have the free 3 year version of Revit Architecture 2012
Message 8 of 9
TravisNave
Reinstall as stand-alone.
Autodesk Forums:
Message 9 of 9
in reply to: TravisNave
(From Travis):You should also consider making a system environment variable named ADSKFLEX_LICENSE_FILE with the value of @SERVERNAME in addition to the FLEXLM_TIMEOUT value of 1000000.
I've already tried with the hostname and the ip. No success still.
How do I make a System enviroment variable named ADSKFLEX_LICENSE_FILE ...?
Administrator Productivity
