Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
FLEXnet License Finder Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having an autodesk inventor 10 network key error that others seem to have had ("Your application was not able to obtain a license because the FLEXnet license serve manager could not determine where to find the licensing data...."). I've tried the timeout extension fix, without success. I believe my license is properly working, as a status inquiry returns the 1 license issued; total of 0 in use message.
Any help would be appreciated.
Steve
Re: FLEXnet License Finder Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Make sure you can ping the server by name and that you get the correct IP address response.
You should also consider making a system environment variable named ADSKFLEX_LICENSE_FILE with the value of @SERVERNAME in addition to the FLEXLM_TIMEOUT value of 1000000.
What error number are you getting?
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It has been fixed by a support person. I'm not quite sure what they did, but it had something to do with DNS and the server name not being recognized. Thanks for the help, anyway.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That would do it. Testing it with a ping to machine name validates that. Glad you are up and running.
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: FLEXnet License Finder Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Enter the ip instead of hostname.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
"Enter the ip instead of hostname."
saved my life, dude - thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried entering the Ip. it didn't work. Gives me error 15.570. If I have a license file I have no idea where it is. I'm a student and have the free 3 year version of Revit Architecture 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
